'46 Chevy PU
Discussion in 'The Hokey Ass Message Board' started by Smedley, Feb 12, 2012.
  1. Smedley
    Smedley
    Howdy! I have a '46 Chevy PU. I have replaced the king pins, and brakes. I am trying to set the caster. What is the recommended caster setting? The suspension is pretty much original. I noticed that the leaf springs have a slight negative arch. Is that normal, or common?
  2. john mullen
    john mullen
    I wouldnt think so, Is it sitting low in the front
  3. swade41
    swade41
    from Buffalo,NY
    Here's a picture of what my old stock setup looked like before it got trashed, hope that helps.
  4. riviera gasser
    riviera gasser
    from howell NJ
  5. LowKat
    LowKat
    Your springs are probably worn or desprung. There's probably a factory setting recommendation for caster but lots of guys shoot for 7 degrees which is what my 48 is set at. drives nice
