I got the air hose in my paint job!
Discussion in 'The Hokey Ass Message Board' started by Rogueman, Jul 21, 2012.
  1. Normal Norman
    Normal Norman
    from Goshen IN.
    Air hose! Ha! I was painting my '63 Plymouth (some years ago) And had to move the portable compressor to do the other side. As I moved it I ran over the hose and it tipped the compressor into a freshly painted fender, and yes the compressor was running, and yes the flywheel was what hit the fender! Ugly! Normal Norman
  2. LowKat
    LowKat
    at least it was only an air hose...
    my buddy got his cat in his.. paw print racing stripe trunk to hood
  3. FunnyCar65
    FunnyCar65
    from Colorado
    It'll sand out I wouldn't go anything co****r then 800,I prefer 1000 grit on basecoat.Sand it smooth and recoat until full color coverage and you'll be fine.I paint cars for a living,**** happens there isn't anything that can't be fixed.
  4. falcongeorge
    falcongeorge
    from BC
    Video, we want VIDEO!:D:D
  5. 2935ford
    2935ford
    Yup...happened to the fella that was painting my '35 Tudor.
    He called to tell me he was putting more light on the subject but the extension cord hit the left quarter panel and now he has to repaint the whole car.
    I drove out took a look and it was manageable. Most of it rubbed out.
    S$%^ happens!
  6. JimInrADFORDva
    JimInrADFORDva
    Man, that's CUSTOM! $1200 extra... :D
  7. JD Miller
    JD Miller
    I had a bat living in my garage, fugged up a paint job later that night:cool:
  8. vintagedream
    vintagedream
    I was painting the orange on my hood, I guess a wasp was attracted to the bright color, when I saw him he was laying on his back in the paint. **** happens!
  9. Roger Walling
    Roger Walling
    If you should drop the paper into a wet paint job, pull it off as quickly as possable.
    I have done it without and damage, 3 seconds is too long.
  10. kahunah
    kahunah
    from Virginia
    If you are using PPG products, 2000 grit wet down with some 330. It allows you to "wet sand" the base till it's smooth. You can then blend the base coat.
  11. was it a traditional air hose?
    it could have been worse. doesnt look to bad.
  12. kscarguy
    kscarguy
    I see your hose and raise you a bird:
    When I was young and painted cars outside...a bird pooped on my car and on the hand I was spraying with, right in the middle of the last coat. YUCK!
  13. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Wetsand it out .You be the judge on what grit to use ,Id try 1500 and buff.But if its worse than just buffing 220 and reprime and reshoot '''And quit trying to scare me,Im painting mine this week..........................
  14. don't worry 'bout it....it'll buff right out ! hahaha
  15. go-twichy
    go-twichy
    i had a friend who had painted his 911 himself and forgot to block his cat door in his garage. the cat walked up and over the whole car. he put the cat in his car and drove about 50 miles and dumped him. three months later the cat showed up at the house. he let him stay.
  16. kscarguy
    kscarguy
    When I paint a car, cat footprints cost extra but ra**** is free.
  17. It's just the base right?
    Wet sand it with no co****r than 800 till smooth.
    blow, wash, blow, tack , apply more base.
    Oh yeah, remember to hold the hose away.
    Then let us know how it went.
