New to the area need a good machine shop around Indy. Sombody to bore a 327, polish crank, resize rods, valve work, screw in studs. Nothing to special just someone who does good work on a old school build. Thanks Ron
I used D&B Machine Shop a bunch of times with good results. They are on the southside, 2702 Brill Rd 317-786-1812
I've used these guys. Do very good work. Not the cheapest but you will know what you are getting. They are located on the east side near 5 points. Dave www.MMCompe***ionEngines.com
Thanks that will help a lot. I drive by M.M. on servive calls, will have stop and talk to them about my motor. I also will check out Schmidts on E. 30th Thanks Ron
