Is she too far gone
Discussion in 'The Hokey Ass Message Board' started by mountainlivin, Jul 22, 2012.
  1. clinkboat
    clinkboat
    from georgia
    Buy a donor car to fill on the gaps....saves a ton of loot. My motor came from a car that disappeared when I pressured washed it so I bought a donor car with a good body. 1+1=good car
  2. slammed
    slammed
    Fuel system. Cooling system. Brake system. Then hit the drive train. Rare car you have there. Look up the production of them. How are the floors?
  3. If the frame is good and you can get it drivable, the rest is just cosmetic.
  4. hell man it still has rockers and most of its 1/4's shes a builder
  5. Oldsmell
    Oldsmell
    Dude that thing is mint to MN standards!!
  6. Angry Frenchman
    Angry Frenchman
    that poor wagon would be a rust spot on the lawn if it was here in New England. everything you guys have is worth rebuilding!!
  7. I think that can should stay in the car.
  8. mountainlivin
    mountainlivin
    Great idea! You all are awesome. After reading these posts I have no doubt that she needs to be revived. Thank you!
  9. RagtopBuick66
    RagtopBuick66
    Too bad it's not a manual transmission! That Pepsi can would make a killer shift knob if you filled it with some 2-part poly casting resin and drilled the bottom.
  10. Gromit
    Gromit
    Great, I think it's a good start you have there. As long as it has floors, throw gas and a battery at it, drop a blanket on the seat and see what you have. ;)
  11. O.Hove
    O.Hove
    from S.D.
    Get it running,blanket on the seat,drive it. Worry about the body work later.
  12. FatDave
    FatDave
    I think you're in good shape... and at least you know what you're looking at.
    In a lot of cases those rusty bits would be hiding beneath a half an inch of filler.
  13. batt69nova
    batt69nova
    from OR
    Too far gone??
    That depends on the person and their wallet.
    Check out my build (and yes, this car is coming together just fine, even though Fred Flintstone would've been at home in it).
    My Olds had/has some very bad floor/rocker/quarter/inner fender rust issues, and I just discovered that the B pillars are shot too.
    It's time consuming, and it's not cheap, but slowly this car is coming back together.
    Old cars aren't getting any cheaper or easier to find, so it seems to me that what we all used to once p*** over is now often times the only choice.
    Those of us who can bend metal into panels have it a little easier when looking for a project, but not much.
  14. HOTRODPRIMER
    HOTRODPRIMER
    I have built worse,looks like a good builder to me. HRP
  15. leadfootloon
    leadfootloon
    I will second that looks good. My 94 Chevy truck has more rote.:eek:
  16. pumpman
    pumpman
    Heck here in Michigan that would be considered cherry. Go for it, just give it time.
  17. volvobrynk
    volvobrynk
    from Denmark
    In Denmark that would be in real good nic, and set you back close to 4500usd. So no not bad at all!!!! You are so lucky!
  18. Faus
    Faus
    I have a 62 four door and the rear frame unibody and trunk floor are pretty bad. I love the little car so I know a guy who builds almost anything out of steel and he made me new rear frame unibody pieces out of heavy gauge sheet steel (far stronger than stock) and I replaced the floor with heavier gauge sheet steel.... This all cost me a little over $100 and it looks factory to anybody but maybe a falcon fanatic. My point is.... If you love the car enough, you'll save it.
  19. choptvan
    choptvan
    Is this the one that was sitting on the westside? In an alley? I almost boughti t. But we scored a good deal on a 64 galaxie wagon with a 390 instead. Was a No brainer for us!
  20. This rare two door should be saved...I've seen worse cars brought back from the brink.
  21. venturesomerite
    venturesomerite
    from CT
    ****, I hope to get my car to that condition.
  22. wallyringo
    wallyringo
    No way you got all the gl*** looks like a complete car, and a 2 door, go for it.
  23. Rich427
    Rich427
    I'm with you guys. We build cars up here in New England that start worse than that
  24. patrick66
    patrick66
    I love responses like these! The eastern and Maritime Province Canadians, and the US Rust Belt and East Coast guys look at that like virgin sheet metal, while the Southwest and California guys look at it as "well, I can find better!"
    It depends on what you want to do with the car, your budget and your abilities. Me? Hell, a two-door Falcon wagon makes for a great cruise night ride and a daily driver. I'd definitely build it.
  25. Nope, looks good.
  26. twistedridez
    twistedridez
    Restore it or fix it up and drive the **** out of it!!!
