identification
Discussion in 'The Hokey Ass Message Board' started by Molin61, Jul 25, 2012.
  1. Molin61
    Molin61
    from Karlshamn
    Hi i have bought this objekt, the body I think is Hudson or Es***, but I realiced that the ch***i is from another car do anyone know? The engine mountingplate fits the frame
    <!-- / message --><!-- edit note -->
  2. Molin61
    Molin61
    from Karlshamn
    I forgot to mention that it has 112 "wheelbase and 30" wide i the middle.
  3. hoggyrubber
    hoggyrubber
    you might try asking on the hudson forum on www.cl***iccar.com . someone there will def know. looks like a bit of this and that to me. i am not sure what the sdan body is. if it's hudson or es*** someone will know there.
  4. Molin61
    Molin61
    from Karlshamn
    I dont thinks It Hudson/Es*** becourse they had 112"wb 1938 and up and It has wooden wheels.
  5. Mr48chev
  6. where on earty is Karlshamn? This is just a question so don't get shook.
    Unless you are doing a restoration I would not be concerned about the ch***is, it is the body that you need to know about so you can find the pieces that go with it. Modify the ch***is to suit your build. It is not likely that you will be using any of the old driveline parts if you are building a hot rod or a custom anyway.
    Those old wheels are wall hanges by the way. They make excellent clocks.
  7. 31Dodger
    31Dodger
    What you have there is a 1930 Es*** sedan....
  8. Sweden.
  9. Thanks Sometimes I don't know if I am looking at made up names or real names.
  10. Molin61
    Molin61
    from Karlshamn
    Karlshamn is in south Sweden. I was thinking use the ch***i and build an old racecar like this ! and i have an old Pontiac flathead 8 to put in it. And the body will be a ratrod whit new ch***i.
  11. hoggyrubber
    hoggyrubber
    they have some threads with those boattail speedster hudsons on cl***ic car aswell. i bet a hudson 6 would be pretty hard to come by in sweden so the pontiac 8 would be a pretty cool replacment. best of luck with both projects.
  12. Molin61
    Molin61
    from Karlshamn
    Do any know where ýou can search for old cars with 112" wheelbase so I can know what frame it is?
  13. looks like what I am looking for 1930 es***!
  14. The37Kid
    The37Kid
    If that is an Es*** ch***is that is the one everyone used to build dirt cars in the 1930's. The rear kickup is perfect. The old car in the center is a Hudson team car from around 1919. Bob
  15. Ruban
    Ruban
    from Sweden
    Hello Molin, a little curious! Have you received any response as to which frame / ch***i you have in the pictures?
    Best regards / Ruban
