chrysler trans id help needed
Discussion in 'The Hokey Ass Message Board' started by 57 finman, Feb 16, 2010.
  1. 57 finman
    57 finman
    have a 4 speed trans that i cant id main case has c-15475 pad has 14072995 7 11 below that is 16334 and below that is cef316334 the rear spline has 27 teeth the front has 10 the side cover has c-13550-2 the front spline round cover has c-15397 or c-15897 thanx for any help
  2. oldandkrusty
    oldandkrusty
    I'm not real ly knowledgable on these ******s, but I'm pretty sure that you need to measure the size of the bearing/bushing on the output shaft to see what the ****** is for. A real good source of info is:
    http://www.p***onperformance.com/
    They know absolutely everything about Chrysler 4-speeds.
  3. HEMI32
    HEMI32
  4. 67 W-30
    67 W-30
    from N.E. Ohio
    Need help in decoding an all -aluminum case short tail-shaft A-833 4 speed.
    code is PP8330478 cast date is 8-10-77
    Short tailshaft with C 133 64 A on it. one shifter mount ahead of motor mount pad
    vin code is 8B 302158
    I just found out i need to measure front hub diameter for ID purpose ( IBR dia)
    Thanks for any help - or direct me to a site that can help. The decode link in above post doesnt work anymore.
    thanks
  5. brad2v
    brad2v
