Buy a donor car to fill on the gaps....saves a ton of loot. My motor came from a car that disappeared when I pressured washed it so I bought a donor car with a good body. 1+1=good car
Fuel system. Cooling system. Brake system. Then hit the drive train. Rare car you have there. Look up the production of them. How are the floors?
that poor wagon would be a rust spot on the lawn if it was here in New England. everything you guys have is worth rebuilding!!
Great idea! You all are awesome. After reading these posts I have no doubt that she needs to be revived. Thank you!
Too bad it's not a manual transmission! That Pepsi can would make a killer shift knob if you filled it with some 2-part poly casting resin and drilled the bottom.
Great, I think it's a good start you have there. As long as it has floors, throw gas and a battery at it, drop a blanket on the seat and see what you have.
I think you're in good shape... and at least you know what you're looking at. In a lot of cases those rusty bits would be hiding beneath a half an inch of filler.
Too far gone?? That depends on the person and their wallet. Check out my build (and yes, this car is coming together just fine, even though Fred Flintstone would've been at home in it). My Olds had/has some very bad floor/rocker/quarter/inner fender rust issues, and I just discovered that the B pillars are shot too. It's time consuming, and it's not cheap, but slowly this car is coming back together. Old cars aren't getting any cheaper or easier to find, so it seems to me that what we all used to once p*** over is now often times the only choice. Those of us who can bend metal into panels have it a little easier when looking for a project, but not much.
In Denmark that would be in real good nic, and set you back close to 4500usd. So no not bad at all!!!! You are so lucky!
I have a 62 four door and the rear frame unibody and trunk floor are pretty bad. I love the little car so I know a guy who builds almost anything out of steel and he made me new rear frame unibody pieces out of heavy gauge sheet steel (far stronger than stock) and I replaced the floor with heavier gauge sheet steel.... This all cost me a little over $100 and it looks factory to anybody but maybe a falcon fanatic. My point is.... If you love the car enough, you'll save it.
Is this the one that was sitting on the westside? In an alley? I almost boughti t. But we scored a good deal on a 64 galaxie wagon with a 390 instead. Was a No brainer for us!
I love responses like these! The eastern and Maritime Province Canadians, and the US Rust Belt and East Coast guys look at that like virgin sheet metal, while the Southwest and California guys look at it as "well, I can find better!" It depends on what you want to do with the car, your budget and your abilities. Me? Hell, a two-door Falcon wagon makes for a great cruise night ride and a daily driver. I'd definitely build it.
