A little help with terminology for the FNG...Please
Discussion in 'The Hokey Ass Message Board' started by KopyKat, Jul 17, 2004.
  1. The letter refers to the cl***ification that the car would have fallen under when drag racing. Such as Altered, Altered Wheelbase Fuel Injected, Carburated... etc. One of the old timers will probably post up a list of all the designations and their exact meaning. The number was just the car's race number. In DoS, I think the 32c is more for looks, though the 32 stands for 1932, and the 'c' probably stands for carburated.
  2. gassersteve
    gassersteve
    On custom bodywork...
    Is there a term for cutting and lowering the profile of an engine hood in order to appear shorter?
    I thought that was nosing?
  3. 55driver
    55driver
  4. buell_guy
    buell_guy
    from Kansas
    Ok, I know the FNG is dragging up a post from the dead, but reading this at work, I had to laugh out loud. Too funny!
    But I do have a question about terms. I was searching for info about Ford banjo rearends (which is how i stumbled upon this thread) and have come across the term "torque tube" and "open driveshaft" multiple times. What exactly are the differences between the two? I ***ume a tube is a tube, but idk. What's the difference? What's better?
  5. A torque tube driveline has a rigid outer 'tube' that runs between the rearend and the transmission. The driveshaft spins inside the torque tube. The entire engine/transmission/torque tube/rearend is held in a rigid line.
    An open driveshaft is the kind that you will find on modern rear wheel drive vehicle. It will have two universal joints (one at each end) and allow the transmission and rearend to be on different angles.
    You can Google these two to find image examples of each.
    'Better' is relative to what type of car is being built and how it is being used. They both have their benefits.
  6. On custom bodywork...
    section-ing.... to remove sections of panel in the hoood trunk lid or body sides to reduce hight of body , same as chopping a top but below the window line.
  7. pie cut,sectioning,or pancaking differs on what region you are from...
  8. Fireball Five
    Fireball Five
    How about " BALLS TO THE WALL '' usually means WOT or WFO. This actually came from WW2 fighter pilots especially in a P38 with 2 throttle levers with a ball on top. [ As in] " There I was, balls to the wall, diving on three of those fokers, ready to give them the whole 9 yards when," whats that question? " No,No, Messerschmits, all 3 of them fokers were flying Messerschmidts!"
    "BTW, The whole 9 yards" also came from fighter planes, their wing mount cannons each had an ammo belt 27 feet long
    Fireball 5
    chryslerfan55 and LOST ANGEL like this.
  9. RodStRace
    RodStRace
  10. Rickybop
    Rickybop
    "Interesting" means "That really ****s sweaty donkey balls."
    Oh...hot rod terms. Ok. Sorry.
    But you may see it here. Hopefully not. Lol.
