Suicide front suspension materials, strong enough??
Discussion in 'The Hokey Ass Message Board' started by jkeckss, Jul 26, 2012.
  1. jkeckss
    jkeckss
    Hey,
    I am going to set up a "suicide" transverse spring set up out front of my 1930 model a and I was planning on putting a round front cross member. I am putting a 302 in the car, hoping to keep the weight down around 2500 lbs. I have available for free some pipe about 2 3/4" OD 3/16" wall, is this strong enough for the front x member or should I be looking into tubing (DOM, chromoly, etc).. perhaps even larger OD or thicker wall?
    Thanks in advance!
    Justin
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    2-3/4" OD x 3/16" wall should be plenty strong. After all, it's attaching to what, 1/8" thick frame material?
  3. Justin,
    Your pipe size is fine but if it is strong enough depends on what type of pipe it is. Is it water or gas pipe? Then it should be used for that. DOM is good as well as mechanical tubing. Chromolly is kind of overkill unless you have a chromolly chassis already.
    I may even go as thin a wall as .125 on my uibing instead of .1875 (1/8 or 3/16) but either will work.
  4. gimpyshotrods
    gimpyshotrods
    Plumbing products are for plumbing.
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    Spend a few more bucks and get the proper DOM tubing. So much depends on that front crossmember being right that you really don't want anything but the right parts up there. And yes, 3/16 is fine.
    Don
  6. gimpyshotrods
    gimpyshotrods
  7. VonKool13
    VonKool13
    I bought some black pipe for a front end, it was close to a 1/4" thick and it was cheap for a big stick. You should go thick if you go pipe instead of tubing.
  8. jkeckss
    jkeckss
    Ok this stuff I have is high quality seamless pipe, I believe it is used in high pressure gas line pipe. Being high quality high pressure pipe that should be sufficient strength eh? :confused:
    DOM is just the way the tube is made right? Doesnt that just mean its seamless or something?
  9. Slag Kustom
    Slag Kustom
    dom just means it is (drawn over mandrel) after the tube is made and welded that is why it does not have the welded seam
  10. Gas and water pipe are made from low quality steel. In a twisting or bending situation it will break. In a suicide front end you out it in a twisting situation with every imperfection in the road. It is not structural pipe.
    You have already convinced yourself that I is OK from the way you are talking but I am going to make a recommendation again, use mechnancal tubing and leave water and gas pipe for water and gas.
  11. Snafu
    Snafu
    You need DOM. Structural tubing is far different than pipe. If you decide to use pipe on the front end.......it will literally be a "suicide" front end. metalsdepot.com is a great site. If you keep the lengths under 8' it is standard UPS shipping. They beat every price I found locally by over $100, on a $230 order!
  12. pitman
    pitman
    This reply is from your friendly materials engineer.
    Structural tubing means no surprises!
    Why most all of the sanctioning Auto racing folks require it,
    in place of plumbing pipe.
  13. Hey I have heard that old bed rails make good suspension pieces. :D
  14. pitman
    pitman
    And never having to say, your sorry! :p
  15. If you get going fast enough before the catastrophic failure you'll never have to say your sorry ever again. :D:D
  16. mrconcdid
    mrconcdid
    from Florida
    ist that why they call it a suicide front end?
    Godspeed
    MrC.
  17. Yep pretty much.
  18. pitman
    pitman
    Can you say "Scrub line?"
  19. Koz
    Koz
    Man, we go through this once a week! DOM only! And by the way DOM is not just welded pipe drawn over a mandrel. It is a true seamless. A lenght of 2 5/8 DOM from Wintec is like $25. Is your life and the life of everyone around you worth it?
  20. Sufficient for a trailer queen that never sees the street, I suppose.
  21. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Sorry, your wrong......
  22. jkeckss
    jkeckss
    Ok so I asked the guy who has the pipe I can use, he said it is made using the DOM method, what is the difference between that DOM and the DOM suggested by everyone? Not being ignorant just curious, and my mind isnt made up yet.. the thing that annoys me about bringing up topics in forums such as this is when people start putting words in your mouth. :rolleyes: I am trying to gather facts. Stop making assumptions and reprimanding people and they are much more likely to listen!
  23. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    There is only one kind of dom. As shown above, it starts out as a welded tube which is then Drawn Over Mandrels to a exact size i.d-o.d. (plus or minus a couple of thousanths) which erases any sign of the weld seam (which is why some think it is seamless)
  24. readhead
    readhead
    ASTM A-53 and A500 grad B, C are the most common types of pipe you will come across. Water pipe if you will. Both are graded for structural use. It sounds like it is 2 1/2" sch. 40. Clean the laquer and mill scale off the outside before you weld it in.
  25. jkeckss
    jkeckss
    Thanks Rootie thats helpful!
    On the MetalsDepot site you guys suggest the round steel DOM tube? Britnell = 80; Tensile = 80,000; Yield = 70,000;
    Which is the most important property?
    Thanks again,
    Justin
  26. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Brinell is the hardness, tensile is the point at which it deforms in strech or compression, yield is the point at which it bends permanetly. If you really think your ever going to reach those limits, you wont have to worry about it. You'll just be a red spot in the road. :rolleyes:
  27. jkeckss
    jkeckss
    Haha yeah red spot is not something I strive to become :p
    So what are the units for those numbers then?
  28. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Pounds
  29. jkeckss
    jkeckss
    wow yeah no wonder I wouldnt make it if I hit those numbers!
  30. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    To be more specific, pounds per sq. inch. Here's a little more info that may be of some interest:
