bbc intake,oval port,square port?
Discussion in 'The Hokey Ass Message Board' started by bodymanmp, Jul 27, 2012.
  1. bodymanmp
    bodymanmp
    is it possible to use a square port intake on round port heads?
    do they make a special intake gasket for this?
  2. RichFox
    RichFox
    I don't think it will seal. Ports just too big
  3. Sleeve396
    Sleeve396
    from Miami
    You can usually get away by using the large square port intake over the oval port heads, but, there will be an obstruction of the airflow because the larger square port will actually be parially blocked by the smaller oval opening, but yes it's been done. Definitely won't work the other way around because you would have air leaks since an oval port intake is smaller than a rectangular port head.
    Just to get an idea take and old intake gasket from a square port and lay it over an old oval port to visually see, might not be the proper way but been there and done that!
  4. squirrel
    I've never tried it, but several guys have said it works fine. use the big gaskets, they should seal ok.
  5. michev
    michev
    I've done it with no problems,picked more rpm's and moved the power curve in the motor,I had a set of ported oval ports. Just use the gaskets for the manifold and you may need a couple more degrees of timing.
  6. michev
    michev
    It will work both ways,I have tried it to find power. I made my own gaskets.
  7. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    Yep it works both ways and most people cannot tell any difference when the square port intake goes onto an oval port headed engine.
  8. bodymanmp
    bodymanmp
    thanks for the info everybody!!!!!!!
