whats the value on a merc flathead motor.
Discussion in 'The Hokey Ass Message Board' started by lilclay81, Jul 28, 2012.
  1. lilclay81
    lilclay81
    from illinois
    I have an all stock mercury flathead motor was just wondering price wise what there worth.
  2. It might be nice if you would post what year.
    Charlie Stephens
  3. lilclay81
    lilclay81
    from illinois
    Came out of a 1949 mecrury 2 dr.
  4. jfrolka
    jfrolka
    How good does it run? Any cracks? How about a picture, a picture is worth a 1000 words to see how complete it is and how well it was taken care of, sometimes.
    Most of the time you can fetch more $ for the crankshaft and it already done from the machine shop along with the block and all the receipts and information and what they were cut to.
    See its a gamble, a costly one, for some to buy a flathead motor without having it checked for cracks.
  5. 19Fordy
    19Fordy
    If it runs, doesn't have any cracks and is "all there" $750 is fair ,I think.
  6. Mr48chev
    Who's buying, who's selling and how bad the buyer wants one.
    Unknown quan***y = Core price Known running engine that has p***ed a compression test has decent oil pressure and has p***ed the crack test 700 sounds about right.
    I paid 400 for a running 8BA two years ago and thought I came out pretty good on it. It still had antifreeze in the cooling system when we pulled it out of the Jeep wagon it had been in for over 30 years.
  7. lilclay81
    lilclay81
    from illinois
    I have it complete from carb all the way to the pan. I would have to get pictures. I took the top end off cause the motor was frozen . So i put oil in the cylinders to try and get it spinning again. I got it for free from my uncle up in minnesota.
  8. Retro Jim
    Retro Jim
    FREE is always GREAT ! Well you can always pull the crank and get your moneys worth from that . Being frozen is always a problem even if it get to move freely again . Rebuilding one isn't cheap .
    Salvage the crank and rods if you can . You might want to check the block out just in case you got really lucky !
    Retro Jim
  9. Rusty O'Toole
    Rusty O'Toole
    $5000 for a good one. A really, really good one. One that was rebuilt with all the right hot rod parts by a well known flathead guru, all ready to run, everything brand new. In other words a really, really good flathead.
    If it's not that good, $100. If the rod is sticking through the block, or the block is cracked, pieces are missing and broken, and if it has been sitting outside in the mud for 10 years maybe $25 or if it is not that bad, $50. Or more. Or less, depending on condition.
    Somewhere in there. Somewhere between $25 and $5000. Definitely between $25 and $5000.
  10. 1952henry
    1952henry
    What he said. Stuck engine surely brings price way down.
  11. flatjack
    flatjack
    I won't pay more than around $125 for a core engine, even a Merc. Bought one last year, yeh it had a Merc crank, but it had been ground .030/.030 and was badly worn. Try finding .050 or .060 bearings.
