Projects Pontiac Part fitting Question
Discussion in 'The Hokey Ass Message Board' started by rfstx1010, Jul 27, 2012.
  1. rfstx1010
    rfstx1010
    from Bear, DE
    I just got a 64 Pontiac 389 engine and slim jim trans that I want to put in my 53 Chiefton. I currently have a 55 287 4 bbl, I used a 59 bellhousing and a 66 4 speed saginaw trans. The question is will my bellhousing or flywheel work or fit on the 64 Engine? I think I already know the answer but jst wanted to be sure. I got the engine and trans for $400 and they came out of a running car. The engine looks clean inside and so does the trans fluid. I check the engine compression and all cylinder are within 5 lbs showing about 175 to 180 each.
  2. How you going to hang an auto trans on a manual bellhousing? It doesn't work that way.
    I wouldn't run the Slim-Jim, sell it to a restorer, the '64 block should have the ear to take a '65 up starter and let you run a BOP pattern TH350, TH400, or 200R4.
    There are slight changes in bolt pattern but the '59 bell should work on the '64 block; not sure on the flywheel.
    The other problem you have is you're going to have to put side mounts for this motor, it does not have the provisions to use the front mount the '55 motor uses - #1 the block is not drilled for some of the bolts and #2 you'd have to swap the front cover over, which may not work due to difference in the main sizes on the cranks.
  3. rfstx1010
    rfstx1010
    from Bear, DE
    the slim jim was attached to the engine when I get it. I have a 59 bell housing and a 4 speed saginaw that I still wanted to try to use, but I don't see that happening without having to buy a 61 to 64 bellhousing and flywheel to make it all work correctly. I haven't checked the block to see if has the starter mounting holes.
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    I am giving you this info from 45 years ago when I played with Pontiacs, so this might be a little off, but will get the experts chiming in to correct me if wrong.
    The 59 parts will not fit a 64 block. You need a 61-64 bellhousing from a full size car and a flywheel from a 64 up. I did this swap on a 1963 Bonneville years ago and found out the hard way the 60 flywheel didn't register right on the crank and it shook loose in a few minutes of running time.
    Pontiac pulled some real switcheroos back in the 50's and 60's and mixing and matching parts was always a challenge.
    Oh, and 64 was a crossover year for starter bolt holes in the block, early 64's didn't have them, late 64's did.
    Don
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
  6. rfstx1010
    rfstx1010
    from Bear, DE
    I checked out the engine and it does have 2 bolt holes for a starter to mount on the drivers side of the engine block. Does that mean that I can use the 64 to 76 Pontiac bellhousing? The engine is from a 64 Catalina.
  7. 55chieftain
    55chieftain
    61 and up have the same bellhousing pattern, so yes. Only 55-60 is differant. Just have the matching parts for that style bellhousing.
  8. rfstx1010
    rfstx1010
    from Bear, DE
    Ok, that helps out a lot. It much cheaper to go with the block starter and 65 to 76 bellhousing than trying to get a 64 to match the engine. I appreciate the help gentlemen!
  9. d2_willys
    d2_willys
    from Kansas
    You lucked out, not only that it has block starter bolt holes, but 61 to 76 bell pattern is BOP. So finding modern day transmissions with BOP pattern isn't difficult.
  10. Jeff Walker
    Jeff Walker
    So what year did they switch from 7/16 to 3/8 threads bolts holes in the block? We have a 62 389 in the shop that has 7/16 threads.
  11. Engine-Ear
    Engine-Ear
    Alliance Vendor
    Jeff, I believe '64 was the official start of 3/8" holes for bellhousing mounting.
  12. rfstx1010
    rfstx1010
    from Bear, DE
    Ok, so now that I know what I need does anyone have a bellhousing and flywheel they want to part with for my Pontiac?
  13. Screamin' Metal
    Screamin' Metal
    from Oklahoma
    I'm suppossed to be a Pontiac XPert, you've been given good advice. If you want to do a swap like you wanted, a trans dapter is in order.
  14. I have a BOP aluminum manual bell in the garage here -
  15. 55delray
    55delray
    from Florida
    Anyone ever fabbed side motor mounts for the 316/389?
