Can you mix Wide Whitewall sizes?
Discussion in 'The Hokey Ass Message Board' started by kscarguy, Jul 29, 2012.
  1. kscarguy
    kscarguy
    Is it ok to use 2-1/2" whites up front and 4" on the back or will it look wrong? (1941 Ford pickup)
    ADDED - big and little tires (165x15 front / 255x70-15 rear)
  2. tfeverfred
    tfeverfred
    I would think so. As in looking wrong.
  3. swade41
    swade41
    from Buffalo,NY
    My old setup was close to that, 5.60 x 15 front and 6.50 x 16 on the back
  4. kscarguy
    kscarguy
    Is that a 3" whitewall on the front and 4" on back?
  5. Russ B
    Russ B
    With 'big & littles' it usually looks best if the taller tire has a wider white wall, my thoughts. For my Model A, I am doing BFGs 5.90s and 8.20s, 2-1/2" wide WW in front, and 4" wide WW on back.
  6. cs39ford
    cs39ford
    I have 650x16 front and 750x16 on back Back is wider white wall Big and littles
  7. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I've got 5" wide WW's out back and 2.5" up front. It works for me.
  8. deto
    deto
    Check the avatar. 2.25 up front 3 in the rear
  9. I mixed sizes and I think it looks ok.
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    If you are running a taller tire on back you almost have to put a smaller ww on the front or it will look odd. You generally want about and equal amount of black showing on both sizes or the tires will look like they are all ww and no black.
    Don
  11. gwarren007
    gwarren007
    I think most cars look good with the smaller whitewall up front and the larger in the rear. I do think however, some cars can use the opposite logic.
    With fender skirts you can have a slightly smaller whitewall in the rear to level the car (think 1950 mercury or a stationwagon) and the look of the car could be awesome.
  12. oldfart36
    oldfart36
    You tell me. My 29!
  13. If ya 'unt to.
  14. Gromit
    Gromit
    I'm running something like that
  15. unkledaddy
    unkledaddy
    Mix, don't match...............it's pleasing to the eye.
  16. ronk16
    ronk16
    There are no rules for what you like, your ride, your rules! Do what you think looks cool, you'll never be happy pleasing others......
  17. HOTRODPRIMER
    HOTRODPRIMER
    I did. HRP
  18. Hdonlybob
    Hdonlybob
    Not at all...in fact I like it...
    Go for it,
    Cheers.......
