Is this a Pontiac rear end?
Discussion in 'The Hokey Ass Message Board' started by fast356, Aug 2, 2012.
  1. fast356
    fast356
    Was told this was a Pontiac or Olds rear end from '57. Any help on the ID appreciated. Rod in Escondido
  2. landseaandair
    landseaandair
    from phoenix
    Nope, could be a Dana?
  3. Nope!
    Pontiac looks similar by design to a Ford 9".
  4. landseaandair
    landseaandair
    from phoenix
    Could also be a British built version of a dana like used in the 50s Jags and MGBs.
  5. fast356
    fast356
    Car was ***embled in 1958 through 1959, so it wouldn't be an MGB. Has to be earlier than 58. Sure appreciate the comments. Another JJ mystery to be solved.
  6. squirrel
    Probably a dana 40 or 44. The 44 was used in lots of Fords in the early-mid 50s, such as pickups and wagons and early T birds
  7. landseaandair
    landseaandair
    from phoenix
    Just found an article on that car and while it says little about the axle, it does say the transmission was pirated from a C Jag.
  8. fast356
    fast356
    Correct. The C jag gearbox is long gone, as is the Hemi, but the diff is still in the car. Always thought it was a Pontiac, but now I'm researching it and I'm thinking I was incorrect (for 40 years). Rod
  9. 49ratfink
    49ratfink
    that's not really the side we need to see to determin its origin.
  10. squirrel
    That is the side we need to see to determine that it's not from a Pontiac earlier than 1964.
  11. landseaandair
    landseaandair
    from phoenix
    Here's a Jag XK140 rear for comparison. Looks the same.
  12. fast356
    fast356
    Thank you, LS&A... it does look like the XK unit. My, My. Very surprising, but it does make some logical sense. If the drive train componants were selected at the same time, then it may be Jaguar. JJ is a wonderful resourse.
    Rod
  13. bulletproof1
    bulletproof1
    from tulsa okla
    im betting dana 44,,,
  14. landseaandair
    landseaandair
    from phoenix
    Salisbury 2HA or 4HA is the British version.
  15. squirrel
    Probably the british one, if it's in a little sporty car. They're not very wide, are they?
  16. landseaandair
    landseaandair
    from phoenix
    Pretty much all itty bitty.
    Here's the car in question, even has knock off wires.
    Just found another hitch in this other article following it though. Says the axle is Lincoln. Could be either but the U-joint looks Jag to me?
    1950 Merc. Dana 41/44?
  17. squirrel
    They often have the model number cast on the outside of the housing, perhaps next to the axle tube on the back of the flange near the cover.
