Teflon tape or?
Discussion in 'The Hokey Ass Message Board' started by guy1unico, Aug 2, 2012.
  1. guy1unico
    guy1unico
    Tried to install a cool Mooneyes temp gauge on my a head of my 40 flattie. It still weeps anti freeze and I've put a good three spins of teflon on the threads. Anything else i might try?
    Thanks,
    Guy
  2. Ace_ChopShop
    Ace_ChopShop
    Try some tru blue, thats what we use in avation on some things... You will never get it off is the thing!
  3. Unkl Ian
    Unkl Ian
    Old Teflon tape was much thicker.
    The cheapie new stuff is paper thin.
  4. squirrel
    Or figure out how the fitting is supposed to work. If it has a nut that holds in the bulb, then you should not bother trying to seal the threads, because they aren't supposed to be sealing the fitting.
  5. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    If it's a NPT thread (pipe thread), pull the gauge and chase the threads with a pipe tap to the point you are JUST cutting clean metal. Personally I prefer liquid teflon sealant over tape, but if you have clean fresh threads you shouldn't need any at all.
  6. Paul
    Paul
    Editor
    if it's br*** it gets no sealant
  7. sunbeam
    sunbeam
    If its electric tape can mess with the reading. Silicone sealer works pretty well.
  8. Dane
    Dane
    from Soquel, CA
  9. T McG
    T McG
    from Phoenix
    Cl***ic Instruments recommends anti-seeze
  10. metlmunchr
    metlmunchr
    Not necessarily true. The only pipe thread that's designed for use without any sort of dope is a dryseal thread. Most parts house br*** fittings do have dryseal threads, but there are plenty of other br*** fittings, both past and present, that do not have dryseal pattern threads.
  11. JEM
    JEM
    I never use the tape in anything automotive.
    If it's a pipe-thread then the Loc***e teflon goop in a tube. If that doesn't work you've got problems with the threads or the apparatus itself is leaking somewhere.
  12. gimpyshotrods
    gimpyshotrods
  13. Are you winding the tape onto the threads in the right direction?
    With the bottom end of gauge threads facing you,the tape gets wound around them clockwise.
    If wound the other way,you take the chance of the tape bunching up/catching on the female threads in the head,removing the tape
  14. Fortunateson
    Fortunateson
    When the white teflon tape doesn't work I use gas line (natural gas) tape. It's yellow and thicker.
  15. langy
    langy
    I like to use the liquid teflon, works well or the ARP thread sealer is good too.
  16. 6-bangertim
    6-bangertim
    Ya, my MOON mechanical gauge also weeps a drop or two of coolant. I HATE TEFLON TAPE WITH A P***ION, just won't use it. For years, PERMATEX#2 did the trick for me. I was given a tube of Teflon Pipe Sealer, works OK. Teflon tape shreds during ***embly and ends up right where you don't need it - fuel systems, oiling systems, cooling systems. TRUST ME - the **** will create more problems than it will ever solve!!!
    Let me know how you solved your weeping sender!
    Good Luck, Tim
  17. bonez
    bonez
    from Slow lane
    The arp sealer is nice, i used it on an airtank at 175psi and was 100% leakless.
    Ive used the loc***e too somewhere else, no leaks but its a ***** to unbolt.
    Teflon should work. If it works on hydraulics a gauge on a flattie should be zero problems really.
  18. Jimv
    Jimv
    If you put teflon tape on correctly it works great!( and yes there is a right & wrong way)Also a trick is to start it and leave the first thread bare.
    Also the one rule of teflon tape is you "DON'T USE IT ON GAS LINES"!!( You must have missed the memo!lol). When used properly its great **** & it also allows you to unthread it easy when it has to come apart!
    I use to work on boilers & never really found much that teflon tape couldn't seal.But like someone said it could insult electical gauges.
    JimV
  19. Come on now, its the tape. The 47 billion threaded joints in existence are all wrong too.
  20. odins701
    odins701
    5 to 6 wraps of teflon tape.
  21. oj
    oj
    I prefer, the ARP sealant. It sounds like something is wrong with the threads of either the gage or the head. Did it leak before the gage? Lots of gages have multi-purpose threads and are not American Standard Pipe Thread, there are 3 or 4 different pipe threads and some of the lesser quality (cheap junk) have a peculiar thread that falls right between all of these. If you have a look in mcmaster-carr br*** pipe fitting section you'll see what i mean about the pipe threads.
  22. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    So true sounds like something a pipe fitter told me years ago.
  23. Paul
    Paul
    Editor
    ok, I will have to concur.
    I learned to ***emble br*** fittings dry from my chief engineer when I worked on boats in Alaska.
    his reasoning was that br*** is self lubricating, maleable and will eventualy reject any chemical compound applied to it.
    I did not question it and have never had an issue, except maybe when threading br*** into something softer, like aluminum.
    but will have to agree, no two threads can be cut to match perfecty together, there will always be a minute gap that will have to be filled.
    either by overtightening to the point of distortion or with some sort of compond.
  24. Larry T
    Larry T
    242 (blue) Loc***e is also a sealant.
  25. outlaw256
    outlaw256
    ive used permatex pipe sealant. thick stuff! i keep little artist brushes in my box .just grab one and twirl on some sealant, paint the threads and no leaks. ever.
  26. nick_c
    nick_c
    from texas
    I use hondabond. The should sell it at the Honda auto dealer. This stuff is the best sealer I've ever used. Works lots better than anything described above. If you try it you'll live it too.
  27. indianmark
    indianmark
    Loc***e 567 is a teflon paste in a tube. This is the best stuff!
  28. Jimv
    Jimv
  30. jazzbum
    jazzbum
    i've used non-hardening teflon paste before with success
