Projects Unfinished Business: A 1951 Mercury Build Thread
Discussion in 'Traditional Customs' started by Doctor Detroit, Nov 6, 2011.
  1. jfrolka
    jfrolka
    Very detailed and very nice
  2. Doctor Detroit
    Doctor Detroit
    Finally got around to doing some bodywork.. with help from a guy at work who's skills far exceed mine in that area. The roof had a lot of high and low spots that we evened out pretty well, then hit the roof with more epoxy primer. Welded up the hood ornament holes, welded up quarter panel stainless trim holes, performed trunk surgery to fix the bent sheetmetal on the underside where the hinges attach.
  3. farmer12
    farmer12
    Looking great, can't wait to see some color on there!
  4. kiwiandy
    kiwiandy
    Flying into it! Nice work.
    Andy
    Auckland NZ.
  5. BoB Beeman
    BoB Beeman
    What a great job on a great car .
  6. pacoloco
    pacoloco
    Wow thats amazing work.... Got to love the attention to detail and the dedication it takes to restore such a beauty t that level.
    You're an inspiration to all of us, thanks for posting!
  7. Doctor Detroit
    Doctor Detroit
    Thanks for the great compliments... I'm looking forward to the bigger "custom" details coming soon... French the headlights, different taillights, custom interior, grille and bumper details. So far it's been a lot of restoration and fabrication, trying to incorporate small custom details.
  8. desotot
    desotot
    looks good,sure love the engine color.
  9. panheadguy
    panheadguy
    from S.E. WI
    r.
    Cool build. Hope the engine is working out. Might have a radiator for ya.
    Guy
  10. 1930sportscoupe
    1930sportscoupe
    i think you have a merc flathead... i have the same water pumps on my 50 merc motor.Mercury flathead is the only one that has one water pump tha'ts about an inch longer sticking out.Let me know.
  11. leadsledmerc49
    leadsledmerc49
    I like all the attention to detail on this build. Great job!!!!!
  12. Doctor Detroit
    Doctor Detroit
    When I had the pan off, I did look at the crank. It has 1BA stamped into it, which should make it a Ford crank. I've never measured the stroke. I've read that it wouldn't be impossible to have a Merc crank stamped with 1BA, but it is unlikely that it's a Mercury crank. I believe this engine was rebuilt at some point, and I don't know any history of it.
  13. Daaaaang, that looks nice. Keep it up
  14. Leadsled612
    Leadsled612
    Wow! your Merc is clean and perfect! A great attention to detail you have...looks great!
  15. banditomerc
    banditomerc
    your build looks great...i am not building anything for myself currently.but when I do get another car..it will be another '51 Merv.ur project is great inspiration to all...thanx.
  16. Doctor Detroit
    Doctor Detroit
  17. Doctor Detroit
    Doctor Detroit
    Recently installed the fuel tank, with traditional dents, painted metallic silver imron to match under the floor. Also re***embled the sway bar and idler arm with drag link and tie rods, all painted metallic silver imron. I've also begin tearing apart the instrument panel. The fun part is deciding what custom touches to throw into the instrument panel...
  18. Skirv
    Skirv
    The bottom side looks great! I'm about to do that instrument panel thing myself.
  19. Doctor Detroit
    Doctor Detroit
  20. Doctor Detroit
    Doctor Detroit
    Recently got a bunch of parts back from the media blaster.... about 50 pcs or so. Threw a coat of epoxy primer on them. Tore my seats apart, to find a pretty cool little artifact. They vinyl seat covers that I took off revealed the original fabric underneath. The material from a sack of sugar was used to cover holes in the original fabric. The sack was dated 1965-66 so it wasn't a traditional sack, unfortunately.
  21. michaelvz51
    michaelvz51
    from So Cal
    This is looking awesome, I will be using this information on my build too and want to thank you for continuing to post!
  22. You figure out what your going to do for gauges?
  23. Doctor Detroit
    Doctor Detroit
    For gauges, I'll be cleaning up the factory instrument panel. I have a few ideas in mind for subtle changes, but I'm not there yet. I'm undecided what to do in the radio area. Considering just putting the radio face and ****ons back in, but losing the guts. Might just go with an ipod for music, and lose the radio completely though.
  24. Doctor Detroit
    Doctor Detroit
  25. banditomerc
    banditomerc
    the ipod idea sounds good to me.loving this build....keep it up
  26. D&W
    D&W
    from SoCal
    im glad i joined so i could read this, ill be watching. enjoy building this! im sure enjoying watching
  27. Doctor Detroit
    Doctor Detroit
    Here are a few updated pictures... I recently got the steering box back in, and I've been focusing on rebuilding the dashboard. Steering column will be installed soon too. I hung the front sheet metal on to make sure everything still fit. The front right fender needs a little work, as does the splash apron under the grille.
  28. draider
    draider
    from Texas
    Looking good. That dash is gonna be killer.
  29. Doctor Detroit
    Doctor Detroit
    Thanks... I decided the interior need some color, so the dash, and probably the inside window frames will be painted orange. It's the same as the satin engine paint, but I'm putting gloss over it on the interior pieces. The seats, headliner, and carpet will all be black.
  30. drdave
    drdave
    That's what I did. All I have is the radio face, knobs and ****ons...basically the front of the radio. I have an ipod hooked up straight through the amp as per a post I found here on the HAMB. The set up has a separate volume control module, so I plan on hooking it up to the remaining volume shaft on the radio to hide it even more.
