19" model a wheel question
Discussion in 'The Hokey Ass Message Board' started by nick_c, Aug 2, 2012.
  1. nick_c
    nick_c
    from texas
    Would the 19" wire wheels fit on f100 front brakes and 40 rear brakes. Would I need the Kesley Hayes Adapters found on rally America? Or would the cheaper counter part from speedway work? Speedway Adapter is just a thin piece of Metal not a bolt on adapter like jimmy sells. Here's a link to the rally America page http://www.rallyamerica.com/Adapters.html
    Thanks
  2. The "thin piece of metal" (probably not a very good description) will work for the rear. The fronts will be a problem that you should ask Richard Lacy (earlyv8@aol.com, (626) 338-2282). I am not sure the Rally America one will do what you want, you should call them and ask about your specific application.
    Charlie Stephens
  3. nick_c
    nick_c
    from texas
  4. This is the one you need on the rear where you use the 1940 brake drum/hub. Some people just use a ring for this application. Be sure your studs are long enough for this piece.
    Charlie Stephens
  5. nick_c
    nick_c
    from texas
    Who sells the ring style adapter? Anyone have a link to that?
  6. nick_c
    nick_c
    from texas
    Anyone know if the wheels will fit on f100 front brakes
  7. JohnEvans
    JohnEvans
    from Phoenix AZ
    Only with a spacer/adapter that is about 1.250 thick. And if you are running any more power than a Banger forget it as those wheels are rather frail.
  8. LSGUN
    LSGUN
    from TX
    No, I hear the adapter rings won't work on those drums either but I've never tried.
