4bbl holley on 350 sbc/ leaking from top rail of carb
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Jul 29, 2012.
  1. Master of None
    Master of None
    Vacuum leak, tighten up the carb to the intake again. Or spray carb cleaner around the base of it when its running. If it stumbles, there's your leak. Also check for cracked hoses and rubber lines going to the carb.
  2. 56 ford custom
    56 ford custom
    from Socal
    Also there is a ****** fitting on the bottom of carb at the front. Is that supposed to be open?
  3. slammed
    slammed
    No, It should be covered or used for a purpose.
  4. 56 ford custom
    56 ford custom
    from Socal
    What is it for?
  5. Master of None
    Master of None
    What side is it on?
  6. 56 ford custom
    56 ford custom
    from Socal
    Standing in front of the car its right in the front of the carb at base and pointing to p***enger side
  7. Master of None
    Master of None
    What is your vacuum advance hooked too? The hose coming off your distributor.
  8. swade41
    swade41
    from Buffalo,NY
    Well that's what should be hooked there.
  9. Master of None
    Master of None
    That's why I asked, it explains the rough running too.:D
  10. 56 ford custom
    56 ford custom
    from Socal
    Well what do you know....The vacuum advance "cone" shaped piece on the dizzy has no hose on it...just open. Also there is a fitting on the block or plate that attaches to the front of carb body then the bowl attaches to it. Well that fitting has a rubber cap on it. Is that supposed to be capped? its on the p***enger side of carb but on the front.
  11. slammed
    slammed
    Take some pix.
  12. 56 ford custom
    56 ford custom
    from Socal
    I will do so after work
  13. 56 ford custom
    56 ford custom
    from Socal
    Here are a few pics.
    The first picture is the front base of the car on p***enger side. There is a fitting that isnt plugged or being use. My finger is pointing right at it. Also on the metering block in front see that rubber cap on that fitting? What should go there?
    This picture shows the vacuum advanc has no hose on it/ Where should this go?
    This picture shows the breather hose going to the base of carb
    This last picture shows the hose coming off of the fitting on the vacuum port of intake splitting off to the brake booster and trans.
  14. slammed
    slammed
    Run a hose from the vacuum advance on the distributor to the ****** on the front of the Holley.
  15. swade41
    swade41
    from Buffalo,NY
    The one you are pointing to.
  16. 56 ford custom
    56 ford custom
    from Socal
    Ok...now thats solved. What about the one that has that rubber cap or plug on it? In the same picture.
  17. slammed
    slammed
    Leave it be son. Oh, check all your vac hoses and any other rubber caps for splitting or cracking. Your getting closer!
  18. 56 ford custom
    56 ford custom
    from Socal
    You say leave it be....but whats it for? lol
  19. swade41
    swade41
    from Buffalo,NY
    That carb may be for a specific application that needed another vacuum port, which your engine doesn't. Just make sure it's capped off and not ****ing air.
    Another reason it may be model specific carb is that the pcv (the one your breather is connected to) is usually in the front of the baseplate not the side like yours.
  20. 56 ford custom
    56 ford custom
    from Socal
    Ok cool will do. So for now I have to see what size that hose will be and get a couple feet of it.
  21. RWENUTS
    RWENUTS
    from Nanaimo BC
    The port you're pointing at is manifold vacuum (full time) and the one with the cap is ported vacuum (no vacuum at idle).
  22. 56 ford custom
    56 ford custom
    from Socal
    So just follow the orders as stated before ? Keep the one plugged and other on base connect to advance?
  23. RWENUTS
    RWENUTS
    from Nanaimo BC
    Yup! You'll need some 5/16 vacuum line to hook it up.
  24. slammed
    slammed
    Hey! Yes, hook up as advised.
  25. 56 ford custom
    56 ford custom
    from Socal
    Perfect! So off to the parts store I go in he morning. I think I might aswell do the spark plugs while im at it. They were a but black and looked fouled and smelled like it was running a bit rich. What brand and model of plugs should I get? Gap?
  26. slammed
    slammed
    See the charts for plug selection/engine year. Gap will be given for the plug selected. .035 is a 'standard' for a typical SBC. Put the freshies (Steve Irwin) in after the fine tuning.
  27. 56 ford custom
    56 ford custom
    from Socal
    So not the delco ones? I am not sure of what year or what it came out of.
  28. RWENUTS
    RWENUTS
    from Nanaimo BC
    Your breather on the valve cover we ***ume is a pcv.
  29. 56 ford custom
    56 ford custom
    from Socal
    One is a breather and the other is the pcv
  30. slammed
    slammed
    Delco are fine. The heat range/part number is key. What are the old ones?
