Projects Free gambino kustoms truck notch you cant win if you dont enter
Discussion in 'The Hokey Ass Message Board' started by Gambino_Kustoms, Aug 2, 2012.
  1. 100% Matt
    100% Matt
    Here is our 51 F1 shop build. Its currently apart as we have begun chassis fab. Plans call for a custom chassis, bagged, new drive train (not a 350) and some custom touches to the sheet metal.
  2. Tony Ray
    Tony Ray
    Thanks again Alex.. and you got me motivated to finally get around to re-up my alliance membership again! Just a quick question though.. I tried to hit your store on the site because Im going to need a notch kit reguardless of the contest..and wanna see if you guys have anything else like bag kits or other things for my truck, but didnt see any parts. Do you have a seperate site or something? I need to get the back end of this truck fix so it can run down the road!
  3. shtterbug8
    shtterbug8
    how come my wife's truck didnt make the cut in the latest update? just wondering.
  4. Hot Rod Chris
    Hot Rod Chris
    Here is my fiances truck. 51 five window. it's already got a clip with a 10bolt in it. I proposed to her with the truck on Halloween. I've been dieing to bag it (I already got the bags for it ) and she won't let me until today that I showed her this thread. She said the only way was if we get it she would let me. I got to get her truck on the ground like my car, So help me out Alex! :)
  5. lucky ink
    lucky ink
  6. studebakerdave
    studebakerdave
    how about this truck I need a little more travel. I was going to order one anyway.
  7. I have 58 chevy apache that I`m working on. sits very high. need to lower it.
  8. pickupman55
    pickupman55
    Just checked the thread and saw my post was cut short. I was typing that the Dodge would look cool with the roof chopped and the truck lowered.
    thanks for putting it in the running !
  9. sophisto79
    sophisto79
    Hey Alex, I'm going to have to fix the notches on mine at some point, so here's my '50. Thanks!
  10. Deu55
    Deu55
    Aussie entry needs some work....
  11. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    you must post a pic figure i out
    sorry NO 60's trucks
    you made it
    you get a chance
  12. bstie
    bstie
    I am hoping I qualify I still don't have it as low as i was hoping! Thanks Alex
  13. here is my 53 3100 it needs to lose some altitude to gain a little more attitude. I already have a dropped front axle and some other goodies but all for the front. The rear needs some love. thanks
  14. bstie
    bstie
    I did not post a description of my truck above it is a 1946 Studebaker M5. It has an Air Ride system installed at all four corners but it has no knotch kit in the rear so it still sits to high. I was hoping my running boards would lay parallel to the ground and sit real close but it does not in it's current configuration. When I am finished I hope to have a mild custom version of these cool old trucks. Thanks again Alex.
  15. Dont you think she would look better if she was lower in the rear?
  16. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    you made it
    you get 2 good fn luck
    your wife gets 1
    your down for 2
  17. adamshumard
    adamshumard
  18. wreckfixer
    wreckfixer
    This is my 57' short wide box big window. I am running the original 292 3 speed OD. I have got my dropped axle and disc brakes in front. Next on the list will be lowering the rear, so I could really use the frame notch kit.
    My plans are body work, suede paint and some traditional wheels, wide whites and styling.
    [​IMG][/url]
    upload photo[/IMG]
  19. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    your down
    you get 2 see it pays to be an aliance member good luck
    your in
    you get 2
    you made the cut
    good fn luck yer on the list
    you get 2 i put the star by yer name
    see did i just didnt up date the list !!!
    ps some of you guys dont have a # yet because some guys cant follow the damb rules!!!
  20. How about this mess? flipped the axle to drop the ass. 1953 Ford F100, found as a lost project next to the railroad tracks, where the previous owner decided to chop the top and probably realized he got over his head. So I took it over and started by bringing the altitude down. Guess I can't call it a mild custom with the chop....
  21. johnboy13
    johnboy13
    I'd like to get in if I can. '57 with a '59 front clip. It's getting a Jag IFS this summer so I need a way to bring the rear down.
  22. Thanks again, Alex!
  23. Yes, Thanks for the offering and the chance to win!
  24. chopperrob
    chopperrob
    from ny
    Heres mine. 1956 GMC, this picture is after new subframe and wheels. the rear is a 12 bolt that has been flipped and has a new lowering spring kit with 1" blocks, The box floor is cut out and the frame is about 2.5" from the rear end! I could really use the notch. Benn working on the body and it looks a bit different now though.
      455.4 KB
  25. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    thanxs good luck
    you get a chance
    yer in
    yes you do u made it
    thanxs
    good fn luck you get 2
  26. King Karl
    King Karl
    from N.C.
    Here is my 58 that needs some help.
    Needs to be set down 5-6" all the way around. (after taken off the stands) :D
    Plans are for a 500ci Cad motor, recess and angle the push bumper, shave the drip rails & lead in all the factory seams, 48 Buick tail lights (if I can find them), tuck & rolled bench seat, short lakes dumping at front fender and a few other small mods from stock. Satin (unknown) color on the bottom with a gloss off white top & firewall.
  27. Deu55
    Deu55
    1942 Ford cab will have 39 Deluxe front fenders and grille, Holden front end.. Ford rear,40 rear truck bed and fenders, v8 , auto plan to be every day driver...Rod...
  28. bstie
    bstie
    My 46 Stude It's going to have fenders on it I just have the bed off while we put the fuel tank (took the tank out of an old speed boat we found at a yard) in and finish up the wiring? You can see the tiny c they took out of the frame at the back it just aint as low as I wanted could really benifit from your kit!
  29. shadams
    shadams
    Here is mine, 1950 Chev 3100. Would like to get the whol truck down a bit more at some point. A nice notch kit would be tits....
    As of now, trying to make do with the dang camaro clip, but if I could start over I would stay with the stock frame of course.
    Done too much to list but if you care, here is a link to my build...
    http://www.jalopyjournal.com/forum/showthread.php?t=572898
  30. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    you get 2
    you made it with 2
    you get 2 good luck
    thanxs for the follow up
