1950 Pontiac manual floor shifter
Discussion in 'The Hokey Ass Message Board' started by blown59, Aug 3, 2012.
  1. blown59
    blown59
    from wisconsin
    Hello to all. I have been a reader for some time and now am in need of help. I have a 1950 Pontiac straight 8 with a 3 on the tree. the shifter is really sloppy and gets locked in gear. Im lookin to put in a floor shift. Any help would be awsome.
  2. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    That is a selector type of transmission, to the best of my knowledge there are no floor shift conversions available at this time.
    KK
  4. blown59
    blown59
    from wisconsin
    I was looking a the Spectre shifter and thought maybe that would work, but wasnt really sure. Thanks
  5. 55chieftain
    55chieftain
    Outside of fixing what you have now, another option would be to find a 37-38 Pontiac trans if you can find one. Same trans but floor shift. If your trans is good you just need the top plate with the shifter.
  6. daliant
    daliant
  7. davidbistolas
    davidbistolas
    Neat. So the small arm basically selects what the big arm is doing, and the big arm does the actual shifting.
    First gear: both arms forward
    Second gear: both arms back
    Third gear: little arm forward, big arm back
    Reverse: little arm back, big arm forward
    Is that right?
  8. davidbistolas
    davidbistolas
    Question - are newer front drive (thinking Cavalier etc) not selector shifters? Once cable selects, the other cable shifts, no? Could one of these be adapted?
  9. johnny bondo
    johnny bondo
    from illinois
    seems almost easier and cheaper to just put in a t5. but i did like that early ford top conversion posted in that thread.
  10. 40FordGuy
    40FordGuy
    Someone did offer a floor shifter for the "selector" style trans,.... I like that topshifter idea from 55 Chieftan.. Definitely won't have any linkage issues with that.
    4TTRUK
  11. bschwoeble
    bschwoeble
    Hey,if I can put my 2 cents worth in. Back in 1962-63 ,my buddy Jerry Williams and I made floor shifts for our cars in high school auto shop. He had a 53 Olds.and I had a 55 Olds. There was an article in Car Craft (?) about a company that was making conversions for these cars. The pictures where very clear,and we just counterfeited the design. I don't it was that hard to do. I can't remember what issue it was,but i think they put it in a 57 Olds. Hope that helps.
  12. blown59
    blown59
    from wisconsin
    Got an e mail from a tech a SPECTRE parts and was told that SPECTRE shifter part # 6413 will work for me. Anybody use one of these. Dont wanna buy junk, I can wait to find a factory 37-38 set up.
  13. 55chieftain
    55chieftain
    Let me look back into some older info I had. I was going to buy a 37-8 trans for my 41 from a Hamber. I'll pm you the info when I find it or let him know about this thread it to see if it's still available.
  14. The T5 swap may be better in the long run because it will also keep the eight happier at highway speeds with the overdrive gear.
  15. blown59
    blown59
    from wisconsin
    Would a 1955 Pontiac Hydramatic bolt up to the straight 8? I got a line on one for $ 100.00 total rebuild.:confused:
  16. Yes, it would probably work, there's not a ton of difference in the two. Will need a ****** cooler. Trouble with those Hydros is not many guys know how to rebuild them these days, there's always the chance it's not done right.
