inline 6 builds
Discussion in 'The Hokey Ass Message Board' started by 64cummins, Aug 6, 2012.
  1. 64cummins
    64cummins
    from kansas
    I know you guys and gals are out there that are still sporting the straight 6s let's see them and hear about what you are doing I will add mine .040 over bottom George's bump stick 3 gl*** bowl Holleys all powder coated crooked horse traded air cleaners progressive linkage .035 off head or more good valve job barker hi lifts soon to be t5 and 430 gears
  2. jeffs_sledz
    jeffs_sledz
  3. BISHOP
    BISHOP
    why 430 gears
  4. Dale Fairfax
    Dale Fairfax
    You could use a bunch of these too: .........,,,,,,,,,,,,
  5. MrFalcon62
    MrFalcon62
    200 Cube Falcon Six:
    -Offy tri-power manifold with 3 Weber 34ICT's
    -Blueprinted Clifford Performance head
    -Clifford Performance hydraulic cam: 264 duration/0.474 lift
    -Clifford Performance 1.6:1 rockers
    -Pertronix 2 electronic distributor conversion
    -Pertronix Flamethrower 40,000 volt coil
    -Cl***ic Inlines dual roller timing chain
    The rest of the driveline:
    -Borg Warner T5
    -Ford 8" posi rearend with 3:80 gears
    and, boy, she scoots!
  6. 64cummins
    64cummins
    from kansas
    I. Want . To have fun with it and 430 will he lp that then over drive will drop that top rpm down.
  7. 64cummins
    64cummins
    from kansas
    Any others out there
  8. HOTFR8
    HOTFR8
    Inline 6, 170 Pursuit very worked over. Carby is a Holley copy of a Weber. A Toyota 5 speed gearbox coupled to a 9 inch Ford Differential with 4:86 ratio.
    Inline 6 in my 48 Ford. 6BT ***mins 5.9 Litre. C6 Auto and US gear overdrive.
    I also have an inline 6 in my international truck. But I doubt that would interest you.
  9. 54hotrodder
    54hotrodder
    She isnt pretty, but she gets the job done.:):cool:
  10. Most fun I have ever had in the hobby!
    Don
  11. Johnnymurt69
    Johnnymurt69
    I just built a 59 235 for my 53 Chevy 60 over delta cam 848 head fenton headers clifford manifold with a four barrel carb saginaw 4 spd with a 57 chevy rear with 3.70 gears.I also went with hei distributer. Motor runs like a bear!
  12. Johnnymurt69
    Johnnymurt69
    pics
  13. NickJT
    NickJT
    from S.E. PA
    It is a DOHC inline 6 and you said Toyota so I couldn't resist posting a pic of my very non-HAMB'ish inline 6 2JZ. It's a nice little motor, though (imo)
    It's the only one I have right now but I'm working as fast as I can to fix that.
  14. ^^ sum *****! twins :)
  15. boucher racing
    boucher racing
    from nashville
    Inline 250
    .030 over Forged TRW pistons
    turbo spec Lunati cam (212/202, 114LSA, .465/.458 lift)
    Stock bottom end
    ARP head studs
    Stock head with Z28 valve springs
    Hogged out factory intake- 2bbl
    Stock exhaust manifold w/ J-pipe to turbo
    Garrett T3 turbo, waste gate set at 5 psi
    Holley 2300 2bbl blow-thru carb
    HEI ignition
    1963hoopty likes this.
  16. chevelle bob
    chevelle bob
    from Linton
    I have 56 235 sitting in the floor of my shop. New fentons, offy tripple intake ready to go on it. Just have to find three carbs.
  17. i'm buildin a 27 chev RPU that'll cop a 53 desoto flathead six with twin carters and whatever other go fast bits i can pick up for reasonable money.
  18. hkestes
    hkestes
    57 Plymouth 230, .030 over, Edgy aluminum head, Offy intake, Carter/Webbers, Fenton cast iron headers, S10 HEI dist. In front of a 53 model Borg Warner R10 OD transmission and stock 4.10 gears in my 48 Plymouth Club Coupe.
  19. FrozenMerc
    FrozenMerc
    My Ford 300 I built up for my OT shop truck.
    Holley 600 on Offenhauser Intake, Comp 270 Cam, Hedman 3x2 Header, plus port and head work. It will absolutely run circles around similar year 302's and 351's.
  20. HOTFR8
    HOTFR8
    I do not know about that engine but the 5 speed behind my 170 really makes that little inline 6 fly.
  21. Gigantor
    Gigantor
    My friend and fellow Hamber Roger is helping me build a 32 style frame from scratch, stretched 5 inches in front of the firewall to accommodate a big Hudson 308 for my 30 Model A roadster.
    I've been slowly gathering speed parts for the old Hornet engine and am still not decided whether to run a Hudson transmission converted to floor shift or pony up the big bucks to get the adapter to mount a T5 to it instead.
    I will be starting a build thread when I feel I have enough progress shots to warrant a story. For right now, despite all the work so far, there is not much to see, but I am very grateful to have met Roger and have his help and advice as this goes forward. All I know for sure is that if we keep going with the attention to detail, this little roadster will be a very, very bad girl.
  22. hey gigantor that sounds like a really cool car, those hudson 308's are awesome. i've got a poster of this one hanging on the wall above my bench at work.
  23. amodel25
    amodel25
    Ford 226 flathead, .060" over, Nielsen reground 3/4 cam, Nicson Intake, Knudsen head, home built split manifold, Petronix ignition, backed up with a 3 speed overdrive and 3:73 gears.
  24. willymakeit
    willymakeit
    What kind of fuel mileage do you expect? Compared to a 302/351?
  25. FrozenMerc
    FrozenMerc
    In a early 80's F-150 with the aerodynamics of a small house, it gets 18 mpg all the time with the original AOD still hooked up behind it. Mileage drops to about 12 with the car trailer behind it. I have never heard of a 302 / 351 getting better then 15 or 16 in a similar truck.
  26. Chris F100
    Chris F100
    Heres my 223 - .080 over , cam, headers, weber 2 barrell
  27. 64cummins
    64cummins
    from kansas
    What cam you got chris f100
  28. Keith English
    Keith English
    54 235 in my 53, bored .040 over, mild cam, decked block and milled head, all new valves, and bottom end. fentons and a few chrome goodies. future plans are a dual carb set up and a change from the 70 3 spd ****** to a T5
  29. swimeasy
    swimeasy
    You got that right-Best motor Ford ever made!
