Need Help Installing So Cal Hairpins
Discussion in 'The Hokey Ass Message Board' started by rcnut223, Aug 8, 2012.
  1. rcnut223
    rcnut223
    from wisconsin
    Need a little help...
    I am installing SoCal Hairpins on my 32 . I selected the stainless ball joint style ends. My questions is how do I weld the frame tabs to the frame.
    I have taken a few pictures demonstrating the 2 options.
    Which is correct, 1&2 which keeps the ball joint straight, has the tab at and angle to the frame or 3&4 which angles the ball joint but the tab fits flush with the frame?
    Thanks
    Mike
  2. brokenspoke
    brokenspoke
    I would think flush with the frame
  3. 3quarter32
    3quarter32
    Picture two or four would be my choices. Preferrably two. I really don't think it would make any difference which one of the two were used, but two looks best.
  4. gnichols
    gnichols
    from Tampa, FL
    Are the ball joints straight or angled? Gary
  5. Tee
    Tee
    I would say 4
  6. I think 4 looks best. If you really want the rod ends to be at a 90 degree angle pic 2 would then be best
  7. MIKE47
    MIKE47
    from new jersey
    4 looks best. A little turn in them isn't gonna make much matter in the direction they are turned as they don't work side to side in that axis. They will of course swing up and down then roll as the hairpins roll. I'd go with 4, as a matter of fact I did.
  8. rcnut223
    rcnut223
    from wisconsin
    Gary
    The ball joints are straight in picture 2 and angled in picture 4
  9. i have used three So-Cal frames and the tabs are welded on more like #2
  10. gnichols
    gnichols
    from Tampa, FL
    I don't think I was clear, but some rod ends used on bones / pins / 4-bars are available with angled shanks. The angles vary but using a pair with a slight angle might help square-up your mounting bracket with the edge of the frame. Gary
  11. rcnut223
    rcnut223
    from wisconsin
    Gary
    Ok I get where you are going, no these are straight.
  12. rcnut223
    rcnut223
    from wisconsin
    with the ball joint I was not offered any choice. Straight was it.
