Need king pin bushings line honed in Phoenix
Discussion in 'The Hokey Ass Message Board' started by DannyBoy, Aug 11, 2012.
  1. DannyBoy
    DannyBoy
    from Arizona
    Anyone have a suggestion for a machine shop in Phoenix, AZ, that is qualified to line bore or hone some king pin bushings for some round-back 1940 Ford spindles?
    I used one machine shop close by who claimed they could do it. They obviously honed each one separately because the king pins didn't line up even close. They claimed that the spindles were no good, because they were crooked. At least they didn't charge me for their mistake, just cost me some new bushings.
    That is why I need some recommendations.
    Thanks in advance!
  2. Fenders
    Fenders
  3. need louvers ?
    need louvers ?
    Steve at Industrial Ch***is has the proper reamer to do it with, but not a pin hone. That might change pretty quickly though as he has located a pin hone.
  4. 29sportcoupe
    29sportcoupe
    from arizona
    Steve at Industrial did mine while correcting my front hubs. Turned out perfect!
  5. Dan Timberlake
    Dan Timberlake
    "They claimed that the spindles were no good, because they were crooked."
    I guess that could be true.
    Did they tell you the king pins didn't fit, or did you find out when you started ***embling things?
    It would have been more helpful to some kind of test measurement with bar stock that fit in the raw bushings.
    Do they do head work, and would they quote replacing valve guides in a BB Chevy ?
    http://www.hastingsmfg.com/ServiceTips/chevrolet_396_and_427_valve_guid.htm
    blindly resizing anything by following the "old holes" individually or even a "new" bushing hole is really looking for trouble. Yes, it "cleans up" with the least amount of material removal, but the new bushings may have been made with reasonable but imperfect concentricity, and then might have been installed coincidently with the worst possible orientation, with the end result just like happened to you. Cylinder Boring bars that reference off the deck surface can perpetuate or even create errors whether installed at the factory, or created during a rEbUiLd.
    At least rough machine the bores using a line reamer then finish hone individually for fit.
    Honing pressed rod pin ends for full float, or resizing rods with new bushings by honing can similarly end up with sadly "bent and twisted" rods.
    Some don't know, some don't care, some just can't Check straightness before and after Align boring/reaming/honing stuff. It's a big deal.
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    + 1 for Steve to ream or try Morrison Auto Machine on W. Glendale Ave in Glendale for honing.
  7. DannyBoy
    DannyBoy
    from Arizona
    Thanks for all the help! I will be following up on it next week!
  8. N2hotrods
    N2hotrods
    If you are out in the east valley my shop can do it.
    N2hotrods 480 262 8712
  9. Zookeeper
    Zookeeper
    I've done it a few times with our small Sunnen hone. It takes all of 5 minutes to set them up plus 5 minutes to hone them to a perfect fit, so don't let a shop tell you some horror story and charge you thru the nose.
  10. DannyBoy
    DannyBoy
    from Arizona
    Many thanks to all of you who responded. I took my spindles to Morrison Machine in Glendale, they did an excellent job, at just $20 per side. I dealt with Jim, and he was very knowledgeable and even did them for less than he quoted after he found out I had already pressed in the bushings. He also resurfaced a flywheel for me. And he had them done next day. I wouldn't hesitate to recommend them to anyone!
  11. MATACONCEPTS
    MATACONCEPTS
    I've always done it with a rolled up piece of sandpaper with NO backing just the sandpaper. It doesn't take much at all. Clean & grease. VEry, very simple.
