Ford-O-Matic slipping when warmed up
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by michaelcainarts, Aug 13, 2012.
  1. michaelcainarts
    michaelcainarts
    Hello all. This is my first post, and my first car project. I just finished taking the engine, transmission and rear end out of one '59 Edsel Corsair and putting it into another. I also lowered it 2 inches with the help of another thread here. It worked perfectly and glad you are all here.
    Now, getting to the point... What is happening is that when I start the car, the transmission works properly. Reverse works. First works, and it seems like it goes into second. But, I have not had the car going faster than about 25mph, so I understand I may be wrong about that.
    As soon as the car warms up, I lose pressure in the transmission, and the car slips out of gear for about 20 seconds, or more. Then it comes back in slowly. I can drive for a bit longer, and the whole thing happens again.
    I haven't pulled the pan and cleaned the filter yet, so I am going to start with that. But, if anyone has some insight, please feel free to share.
    I knew the ****** was questionable when I put it in, but it was better than the other.
    Thanks
  2. eastwildlife
    eastwildlife
    Vacuum modulator? Plugged filter? Is this a 2 speed or fmx 3 speed?
  3. michaelcainarts
    michaelcainarts
    2 speed. Hoping a plugged filter. Will find that out as soon as my gasket comes in.
    Mainly trying to see if other people had the same problem before.
  4. k9racer
    k9racer
    may not have a filter. drop pan and clean strainer or screen ,, also is the fluid full check dip stick at idle when engine/trans is at operating temp.. NOW ADD some intro type info.
  5. michaelcainarts
    michaelcainarts
    I guess I shouldn't have used the word filter. Was expecting it to be a screen. Checked it at operating temp and it is full. The gasket will be coming in next week.
    And, I thought I already added intro info. Will get that out soon.
    Thanks.
