00 grease- anyone have any experience using?
Discussion in 'The Hokey Ass Message Board' started by artemas, Aug 15, 2012.
  1. artemas
    artemas
    I was chatting with a buddy the other day and he mentioned that a 'new' grease exists called SNAPPER GREASE. I looked it up but dont find much info on anyone using it and the results. Has anyone used 00 grease (AKA Stens 00 Grease) before and what are your thoughts? I was thinking of using it in my steering box.
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    It ain't new ! Visit your local farm tractor dealer/supply and ask for "picker head or cornpicker head " grease. It is a flowable grease that works geat in older leaky steering boxes ,stays where it's needed, doesn't chanel like ch***is grease.
  3. artemas
    artemas
    so you are an advocate of this grease? Will it leak at all or not at all?
  4. GeezersP15
    GeezersP15
    from N.E. PA
  5. man-a-fre
    man-a-fre
  6. artemas
    artemas
    Thanks Man a fre, I did a search before posting but obviously 00 snapper grease wasnt in your post.
  7. daliant
    daliant
  8. squirrel
    What are you planning to use it in? It's great for manual steering gears, but a bit thin for ch***is or wheel bearing use.
    #2 is the most common grease.
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    His last sentence said steering box.
  10. Vimtage Iron
    Vimtage Iron
    Your local John Deere dealer or petroluem distributer will have it as corn head grese, the local parts house guys will look at you with a dumb look.
  11. squirrel
    For those of us in non-agricultural areas, CV joint grease works ok, too.
    V8-m likes this.
  12. I'm reading into #2 grease as what I know.
    Look at the label closely. EP-2 or NGLI #2 rating. Pick hi-temp type for universal joint usage and overkill in hotrod wheel bearing grease applications. It's standard for semi truck usage and more. Load and heat generated.
    I like red label Mystic JT-6 Hi-Temp a lot. Other manufacturers produce products that will do the same job.
