My Build Thread on my 1950 Chevy Deluxe 2 door sedan
Discussion in 'The Hokey Ass Message Board' started by cncd11, Aug 14, 2012.
  1. cncd11
    cncd11
    Well here it is my first build. Picked this car off of CL for yes... $1000.00. Not to bad really.
    The bad... Quarter panels, door bottoms, rockers and tail pan have some rot through. Drivers door gl*** is busted out, front floor pans are rotted through. The engine does not run, which i am not to worried since i have another engine currently at the shop getting hopped up.
    The good... Once quarter panels, rockers and tail pan are replaced, the chopping begins!!!
    Plans for the build...
    For the power-train: I currently have a 235 out of a 58 Biscayne at the engine shop getting rebuilt. Crank is getting lightened and balanced, oversize pistons, port and polish the head, Updated valves and seats (so i can run unleaded) custom ground cam, bump compression, clifford tubular headers, and a tri power rochester 2gc carb setup. Which is something i have not seen done yet, but if so post some pics on here so i can get some ideas. I will also be using a 700-r4 trans for the overdrive.
    Ch***is and body...
    Frenched headlights, antennas, tail lights (which i am not sure which ones i want to run yet) It will then be Chopped with slanted posts, shaved drip rails, shaved gas tank filler door. I will be running a fatman kit up front with air bags, and using Gambino Kustoms notch, custom 4 link, with custom bag mount and bridge. As far as paint goes... I have to much work ahead of me to think about a paint scheme at this point lol. Well let the rodding begin!!!
  2. cncd11
    cncd11
    Here are some pics of the car the day i brought it home which was last Saturday.
  3. cncd11
    cncd11
    Progress i made this Sunday.
    seats unbolted and removed.
    interior panels and carpet removed.
    I also removed all the trim from the outside and will be removing the gl*** withen the next few days.
  4. farmer12
    farmer12
    Great project, the car is begging for a chop!
  5. HardTimesHC
    HardTimesHC
    from Seattle
    Hear ya on the bad, same boat. Have fun.
  6. mr.chevrolet
    mr.chevrolet
    dont take it all apart right away. too many guys do that and get overwhelmed later. (i did) one job at a time.
  7. KustomCars
    KustomCars
    from Minnesota
    Sweet! Cant wait for more updates!
  8. Should be pretty rad when it's done!
  9. Rogueman
    Rogueman
    You did good!
  10. ed_v
    ed_v
    from Kentucky
    What you got there is what I would consider the perfect project car:
    • The price. Looks like a great deal for $1k.
    • The trim and (most of) the gl*** is there.
    • It needs work, but it's not one step away from the s**** yard. I always like a project that will require a bit of work and maybe make me try/learn something new. It's not much fun if it's too easy or too overwhelming.
    • There are still parts available for it.
    • Most importantly...... it's a cool car and it's yours!
    Have fun and keep us posted :)
    Ed
  11. cncd11
    cncd11
    s****ed and cleaned and hosed the interior out to get a better idea what i am working with.
  12. fiddy
    fiddy
    The pans look way better than i was expecting
  13. cncd11
    cncd11
    Also degreased and hosed out the engine bay. I need help identifying this engine cause its going up for sale. It has the captins bars above the starter and from what i read this is a 261 but i am unsure.
    here are some pics of the engine and some of the casting/stamping marks. What is it guys/gals?
    last pic is casting on the cylinder head.
  14. cncd11
    cncd11
    Me to!!! Rear seat pan and area under the seat is solid!
  15. cncd11
    cncd11
    any thoughts on the engine?
  16. 1low52
    1low52
  17. Pharouh
    Pharouh
    When you get to this point,you're done!
  18. fiddy
    fiddy
    Def not a 216. It has the short side cover. either 235 or 261
  19. cncd11
    cncd11
    Awesome! Thanks for the photo shop work there. Gonna save this pic for sure. Makes for a good yea look what i did last night... But not really. It would look sweet without a chop to and all slammed to the ground.
  20. 'Mo
    'Mo
    Engine build sounds stout. 3 2gc's seems like a lot of carburetion!
    What's the story on your avatar car?
  21. RawDeal
    RawDeal
    from Austria
    according to the serial number LAQ should be a 1953 235, cylinderhead number would also fit for a 53 235
  22. so.... are you going to chop it? :D
  23. cncd11
    cncd11
    Yea the engine build will b pretty stout for sure. As far as my avitar car it's a 50 also that I own. Mild custom that I might be making a roadster out of.
  24. cncd11
    cncd11
    Yup!!!
  25. cncd11
    cncd11
    At the muddy roots music festival. Gonna make it a goal to get it road worthy for next year.
  26. rocknrolldaddy
    rocknrolldaddy
    $1K on CL? I'd do that, have fun with that.
  27. greasebandit0801
    greasebandit0801
    from houston
  28. fastcar1953
    fastcar1953
    nice start , wouldn't shave the drip rail though.
    keep everything you're not using and sell when you're done.
    i thought about 3 dueces, was going to block front and back off. run on middle one only. hook up linkage and dummy fuel lines. good luck on build and keep us posted.
  29. Terrible Tom
    Terrible Tom
    Yes! Very good advice.
    Tom
  30. cncd11
    cncd11
    Nice part of my setup is the outers will not be dummy carbs, the engine will support them. My manifold is in process of getting made. As soon as i have some pics i will post them. I am picking up a compressor here in a few days so i can run my air tools. So body work has not been started yet. im sick of sanding for 2 min and waiting 5 if you know what i mean.
