1950 Chevrolet Lowering
Discussion in 'The Hokey Ass Message Board' started by Cheneyboro Kid, Aug 18, 2012.
  1. Need suggestions on lowering a stock 1950 chevy 3100 truck. What about just removing leaf springs? Thanks!
  2. guthriesmith
    guthriesmith
    You can search and find lots of info, but here is a start www.droppedaxles.com There is a tech article for how to lower one with a dropped axle and removing leaves for reference. Sid is great to deal with if you use a dropped axle.
  3. search is your friend. this topic gets covered often have fun. you might even run across my truck
  4. liljonny
    liljonny
    from menifee,ca
    Yup, search search and search til ya go blind! :) how low do u wanna go?
  5. Mr48chev
    You do realize you have two threads going on the same subject?
  6. I will peobably go with a dropped axle later but I am currently replacing my shackle bushings and figured it would be a good time to take a few leafs out. I just didnt know the affects it would have. I know it will be a softer ride and lower it some but dont want a negative impact.
