We shaved everything off my lady's 62 Falcon, and did it with the Spal kit which included 2 door poppers. I also wired it so an actuator releases the trunk latch on the push of a ****on. My question: I want the trunk to "pop" open. (latch opens, but needs some "kick" to pop it. Don't want to spend $25 at the local billet hot rod shop for a single door popper. (I am not really a cheapskate, but don't like giving my $$$ to people like them if I can do it myself. Is there another way? Maybe a high tension coil-spring on the trunk-lid bumpers? Anybody done/made something like this? I would rather pay the $25 in parts at a hardware store and make it myself than buy it if possible. Thanks, Erron
Can it be done? Yes. Do you really want to waste your time screwing around with something that might work most of the time when there is a easily available alternative that is known to work? If so....Design away. Id rather be driving my car than tinkering with something that cane be done easier. My 2 cents....
I appreciate the 2 cents. I just wanted to know if anyone has done it, or knows how. BTW: I saw the feature OSR did on your club...sweet rides, and yall seem down to earth. Keep it up. Erron
Torque one of the trunk springs so it pops it up maybe, thats how 80's electric trunks worked. Or put an extra hood-popper spring on a plate next to the latch (mount it to the deck so it's out of the way to get in the trunk). Simple, reliable, and probably cost less than $5 even if you have to weld up some kind of bracket. Just clean it up and paint it. Dip the spring in some rubber tool-handle coating stuff so it doesn't leave ugly scratch marks on your mount plate, or put a piece of rubber (cut out of an old tire maybe) on whatever it's pushing against when the deck is closed. Lo-tech to be sure, but shoot I don't know how you could make anything electrical work for $25 unless you have an 80's GM with power door locks you can cannibalize for free, or know where one is, and use a door lock solenoid to pop it. Those damn things are a pain to get out, too, they rivet them on and the fastest way off is a chisel on the aluminum backing. Going to see if said solenoids will work the latches on my '50 and do the doors homemade style, FWIW -
Going to see if said solenoids will work the latches on my '50 and do the doors homemade style, FWIW -[/QUOTE] Just make sure the are powerfull enough. I found that a goooood dose of liquid wrench on all door mechs cleans em good, then spray with soapy pater and scrub every part you can. EVERY PART! After clean and dry, I like lithium grease to lube everything. You can test the power of the junkyard solenoids w/ a any # benchpress disc type plate weight. Hook it to batt + ground, hit it QUICK, and if it lifts it, It is probably at least 10# over whatever weight you are using. That is just what I have found. Hope this helps you, and thanks for the info. Erron
In the late 80's, probably other years as well, GM used a small 'arm' to push open doors. Check in the jams of Monte Carlos, Regals, big cars as well. 2 screws, and junkyard prices, and they're yours. You could also make something similar to the available poppers, using a bolt, or a hood adjuster (has a rubber bumper on it) a spring from the hardware store, a piece of tubing the bolt fits into, and a washer and stop nut. Need a diagram?
I think if you were to add up time spent fabing up something, it probably wouldn't be as clean looking as the 25 dollar popper.
Didn't they used to use motorcycle valvesprings, back in the day, as poppers? I think I read something recently. It may be a worthless idea, but there it is. Tucker
In the past I have used one or two small springs attached to the trunk lid or near the lock ***embly or on the trunk opening lip( on the body) and used a washer snd self-tappers to hold them ...works great and CHEAP !! jersey skip
Folks used to use valve springs on their doors "back in the day". I'm thinking gas struts for my VW's doors: it would make them pop & then slowly open up. You could do the same with your trunklid. Cost more than a few bucks, but would look trick IMO. ~ Paul aka "Tha Driver" There is no problem that cannot be solved with the right application of high explosives.
Mid eighties Mustangs (and probably other fords too) have spring loaded door poppers in the door jambs. Head down to the Pick-Yer-Part, and remember the golden rule of the junk yard: If it fits in your pants, it's free.
I had a buddy that did use modified valve springs mounted on brackets for the doors on his lincoln and it worked pretty well. I will admit that creating uses for things/old parts is a damn cool thing to do, i'm just so damn busy with work and life that I dont have the time to experiment with stuff. I usually gotta make it work right away.. oh well..... I hate being responsible sometimes.... Thanks for the comment. We are pretty lucky.We have some good peple and lots of good times. Lifes too short not too.....
Those are NOT "door poppers", they're tensioners to hold the door open. So you're a ****ing THEIF, huh? Come to my place & they'll carry you out in a body bag. ~ Paul aka "Tha Driver" If you can't take the heat, get out of the nuclear reactor.
should be able to use a bolt,a couple of nuts, a few washers and a spring to make a decent trunk "pop".....won't fling it open but'll open it enough to keep it from latching again.
new weatherstripping will usually make it "pop" a little further open for a few years. that is,if yer' trunk is leaking!
The door lock solenoids from the seventies GMs are the ones to use. They look like a can, with a rod coming out of one end, usually formed into a loop with a rubber insulating disc in the loop. These guys are strong. Also loud. And they're real solenoids, not rack and pinion motors, like the stuff used later. Don't use anything with any plastic in it, it's not strong enough. Don't remove the interior handles, either, its not smart (electrical failure: how do I get OUT!! ) Cosmo. As for the trunk popper, look at a hood with an internal cable. They have to 'pop' open, else you're not gettin' in!! I'm thinking spring (leaf, possibly coil, leaf better) in the receiver, arranged to push against the latch when closed.
I would seriously consider gas struts from a junkyard. Find some off a car with a heavy hood or an SUV maybe with a hatch that weighs close to your decklid. Fab up some brackets and you're done. That way if your lady has an armful of groceries she can hit the remote and be done. Just like a new Cadillac
i remember seeing that aswell, im pretty sure it was on the hamb actually. im pretty sure it was in a post ***led tricks and tips or something
This post reminded me of the old timers talking in the old shop about the problems of the doors popping open. One guy remembers stuffing those "pinkies", the soft pink hardball sized balls, into the door hinges. Anyone else ever do that?
****heads like this not to be confused with Tuck, also from Canada. I think you'll find this is NOT the Golden rule of most Hambers.
