History 1941 Ford Four-Banger?
Discussion in 'The Hokey Ass Message Board' started by FC49, Aug 13, 2012.
  1. olcurmdgeon
    olcurmdgeon
    Interestingly, there is a reputed North Dakota '41 pickup on Evilbay now with a four cylinder in it, good pics of the motor and such. 271036931074
  2. Dapostman
    Dapostman
    If the 9N is half a v8, will heads interchange?
  3. FC49
    FC49
    Connecting upper coolant hose to a V8 head would be an interesting challenge.
    Frank C.
  4. Bruce Lancaster
    Bruce Lancaster
    Serious study of the '28-48 parts book would be needed to fully shake out interchange, but looks to me like valve ***emblies and pistons and timing gears are most of the interchange. Parts should be very easy to get due to the armies of N tractors still working or being restored.
    Head looks like a total no-go. Don't have a real count, but looks in the overhaul book pics like stud count is somewhere around 16 or 17.
    Pickup engines with tin pan and fuel pump are VERY scarce, tractor versions all over the place. The public had already figured out that the V8-60 was seriously underpowered and was thus not likely to jump on an even smaller engine in a truck, though the 60 was briefly looking good during WWII with rationing and 40 MPH limit.
  5. JSHAW
    JSHAW
    Great Info! A 1941 Ford a friend is selling. Here is some pics of the engine.
  6. sunbeam
    sunbeam
    Unless your flat head has 18 head bolts you are out of luck. Timing gears and lifters do interchange. An old shop owner here had one he drove until 2 years ago until he went to the resthome . He replaced the engine with a V8 he told me when he got the truck it said USN on the side.
