I have had a small issue with the headlights since day one. With the switch in one position i get all four lights. When I click it I get one regular light only. I tried a new switch and that didnt do it. Any ideas?
Have you tried changing out the one bulb that doesn't light up when it should ? Lights can do crazy stuff sometimes. Don
Well I just went out there to switch another bulb and at first it didnt work. The I noticed one of the wires in the plug was loose........... Im gonna go sit in the corner now.
Haha, don't feel like the Lone Ranger, we've all done similar things. One time I pulled up in front of the windows at a 7-11 and dimmed my lights. All four went out. When I hit the dimmer none would light up, so I figured the switch had to be bad because the odds of all four bulbs blowing at one time was impossible. After an hour standing on my head under the dash changing the switch they still wouldn't work. You guessed it..........ALL 4 BULBS HAD BLOWN and when I replaced them they worked fine. Car's are strange animals. Don
Yup, like forgetting you shut the fuel pump of last time you drove it, then wondering why it won't start.
Oh, btw, here is a wiring diagram of your car in case you ever need it. Don Here is the first half of it. http://www.oldcarmanualproject.com/tOCMP/wiring/5765wiring diagrams/Buick/MWireBuic65_3WD-014.jpg And here is the second half. Keep these links around for future reference. http://www.oldcarmanualproject.com/tOCMP/wiring/5765wiring diagrams/Buick/MWireBuic65_3WD-015.jpg Don
You have to remember that the two outer lamps have both a high and low beam filament, where the inside bulbs are strictly high beams. One of the bulbs has a bad connection to the low beam filament or the bulb is bad.
