HAMB Drags engine carnage pics.
Discussion in 'The Hokey Ass Message Board' started by flamedabone, Aug 21, 2012.
  1. flamedabone
    flamedabone
    Well...one pic really tells the whole story....
    This little engine has been bullet proof for a bazillion miles with a **** load of dragstrip p***es and waaaay too many rpms, so it is no fault of hers. I had a feeling she was hurt on the last p***, but she still limped all the way home so what more could I ever ask?
    Here is the day I put her together. My kid in the pic is now in high school...
    Now, I'm off to the machine shop with a new crank and get a fresh hone job on the block then I'm gonna stick her back together like she was untill next winter when she gets her new Total World ********** Pontiac Engine Of Death. But untill then, she sits for a few weeks...
    Still the best HAMB Drags ever.
    See ya, -Abone.
  2. Ah hell just pin it and put a splint on it until it heals. I thought you maybe in trouble when I saw you dumping that load of pop in it. :D
    At least its a crank and hone job and nothing more my friend. I may want to take a real close look at the main caps but you already know that.
  3. Total World ********** Pontiac Engine Of Death.
    I like the sound of that!^^^^^^^^^^^^
  4. 76cam
    76cam
    Ouch!!!!And man that new total world ********** motor sounds *****in!!!! Can't wait to see that one...
  5. I wanna hear the sound of it from behind the firewall.;)
  6. squirrel
    Well, that'll tend to make a rattling noise.
    Hope to see you on the road again soon!
  7. k5hart
    k5hart
    Damn you work fast man! You really don't want to drive that truck do you.
    Glad it wasn't more catastrophic.
  8. BLAKE
    BLAKE
    We need to put some filings from that crank inside the Yay-Hoo Cup... like, forever.
  9. If someone will send me the broken pieces or some pieces of the broken pieces I will make something up for the fastest broken one, it can be p***sed from year to year as well. Each year or each break it can grow.
  10. 49ratfink
    49ratfink
    carnage? it's only broke in one spot.
  11. Ryan
    Ryan
    ADMINISTRATOR
    Jesus god... It's like going to a funeral and doing that creepy walk up to the casket for the viewing.
  12. Gotgas
    Gotgas
    from DFW USA
    That's a bad*** engine that could drive home with a busted crank! Glad to hear you had a good time! :D
  13. Ryan
    Ryan
    ADMINISTRATOR
    Wait a second... Didn't you let Kevin drive that thing to get food on Saturday night/Sunday morning? That ******* is responsible for this... I just know it!
  14. BLAKE
    BLAKE
    I almost just texted DW to ask if he'd seen ABONE's crank... then better judgment prevailed.
  15. JD Miller
    JD Miller
    I had a steel 283 crank break just like that, threw the front crank pully off the motor and I saw it fly off the side of the road, cracked the block journal too
    Im supprized you block isnt history too
  16. Monkey
    Monkey
    from Owasso, OK
    Glad you made it home safe buddy!!! Always good to see you!
  17. afaulk
    afaulk
    Ahhh, no problem. Ya can probably weld that up and run it a few more years.....well maybe not. Been there and done that, on the + side of things, the crank didn't come out thru the pan.
  18. flt-blk
    flt-blk
    from IL
    You don't mess around, that's really broke.
    Hopefully it's fixible until the world ********** motor goes together.
  19. Don's Hot Rods
    Don's Hot Rods
    from florida
    Boy, that really says a lot about the toughness of American V8 motors. Crank split in half and it still (sort of) ran. Glad you think the block is savable .
    Don
  20. Chris
    Chris
    Wait, when you say "limped all the way home" does that mean you drove it home to SC like that??
  21. Atwater Mike
    Atwater Mike
    I bought a real nice white '54 Ford Customline Coupe with a broken crank (1967, Canoga Park, CA) and drove it 4 miles up Vanowen St. home...
    Made more noise than a jack*** in a tin barn, but the cross break at the throw kept it turning by 'interference'...
    Say, do you know what caused that breakage? Just don't have the same guy turn the rod journals on the next one...
  22. Lumpy
    Lumpy
  23. bobss396
    bobss396
    Sound advice, hope all it needs is a line-hone. And splurge for new internal hardware!
    Bob
  24. Dan Timberlake
    Dan Timberlake
    It looks like a fatigue crack that started out in the rod journal fillet a while ago, and worked its way a little deeper on every power stroke, until there was not enough left to hold on any longer.
    yeah, too small fillet radiuses, or corners, or steps can let a crack get started.
    Any chance it was welded at the last re-grind?
  25. tfeverfred
    tfeverfred
  26. rob lee
    rob lee
    from omaha,ne
    Thats what I was thinking,,,,,Served you well!
  27. so you hangin that on the wall ??? >>>>>
  28. D.W.
    D.W.
    from Austin Tx.
    for real!
  29. D.W.
    D.W.
    from Austin Tx.
    Total World ********** Pontiac Engine of Death.
    YES!
  30. oldsman71
    oldsman71
    glad it didnt hurt the block!!!
