1955 Desoto--Plan to transplant a Chrysler 440
Discussion in 'The Hokey Ass Message Board' started by 51ChevPU, Aug 21, 2012.
  1. 51ChevPU
    51ChevPU
    from Arizona
    I have a 55 Desoto 2 door hard top that doesn't have an engine or ******. I realize that with alot of money, I could try to find a running mopar hemi. In the alternative, I was hoping to pick up either a running 383 or 440 mopar with the torqueflite transmission and use that combination. Anyone out there that may have done this type of transplant with a Desoto or Chrysler of the same vintage? Any comments would be appreciated.
    Thanks.
  2. R Pope
    R Pope
    Geez, yer not putting a 350/350 in it? What kinda hot rodder are ya?
    Seriously, though, any engine room that would fit a Hemi should have no problem accepting a 440. Should be fun!
  3. Squablow
    Squablow
    Plan on swapping out the rearend too, it's got a goofy ujoint system and the drums are a ******* to take off. Cutting down a driveshaft and trying to get the brakes to work will be more h***le than just putting something later model back there.
    Front suspension in the '55 is a nice A-arm setup which is pre-torsion bar and there are disc brake kits available so that should be good, and plenty heavy enough for a big block Mopar. Parallel leafs in the rear should also be fine as-is.
  4. EARLYHEMIBILL
    EARLYHEMIBILL
    from ?
    My buddie put a 413 wedge into a 59 Desoto. Lots-O-room. And that care didn't even have a hemi. And by the way, like the guy before me said, no 350-350? I went to a car show sometime back and the T-Bucket club was there. They were just the stereotypical annoying Ts until I saw one with a blown 440. That got everyone's attention. It originally had a small block, but he went for the Chrysler. Had to do a little modifying to the frame but he said it was worth it. Good luck with your project, Bill
  5. George
    George
  6. Rusty O'Toole
    Rusty O'Toole
    What did the 55s have for a gear shift? Was that the first year of push****ons or was that 56?
  7. Fenders
    Fenders
    mmmmmm...... 55 DeSoto .........
  8. flamed34
    flamed34
    The '55s were a one-year-only shifter on the dash - it has a lever coming out on the right hand side. 1956 started the push ****on.
    I picked up one of these a couple months ago - with the hemi - and drove it home.
  9. dndrodshop
    dndrodshop
    from Wales
    Got a 440 in my48 Plymouth and I'm sure there is less room in my car. A little cut and fit will be needed but that's hot rodding.
  10. 73RR
    73RR
    There are similar swaps over at the Moaparts forum. It is not a 'bolt-in' but the 'fun' factor will be worth the effort!
  11. I put this combo in my 55 plymouth.not a bad fit.just open up th trans tunnel a little.[​IMG]
