Please School Me On Hone-0-Drive Overdrives
Discussion in 'The Hokey Ass Message Board' started by 38FLATTIE, Mar 7, 2010.
  1. 38FLATTIE
    38FLATTIE
    from Colorado
    I've been looking at Hone-O-Drive Overdrives, the universal model 300. I haven't been able to find the instruction/installation sheets.
    I'm thinking about putting one behind my flathead Cadillac, so that I can keep a good rear end ratio, and yet keep the RPM's down on the highway.
    Has anyone used these? Can anyone tell me pros or cons on these?
  2. 61bone
    61bone
    Had one in a 77 Chevy PU. While it worked well, the mount system was less than adequate. I carried a standard shaft with me so I could just drop it out when it worked loose. Mine set in a notched cradle with a couple u bolts to hold it in. It would break the bolts on a regular basis. Once I got it so the bolts would hold, the cradle pulled out of the crossmember. I finally gave up.The whole ***embly is still setting on the shelf in the warehouse.
    It had a short shaft between the trans and OD about 6 inches long.
  3. 38FLATTIE
    38FLATTIE
    from Colorado
    Hmmm. really? Well, it would do more good on my car than your shelf!
    I appreciate the info. Any problem shifting it into overdrive on the fly, or do you have to shift before you start moving?
  4. 61bone
    61bone
    It's going to stay right where it's at. Shifting was never a problem at any time.
  5. 38FLATTIE
    38FLATTIE
    from Colorado
    HaHa! Thanks for the info!
  6. Roger O'Dell
    Roger O'Dell
    I don't think those things are still made a friend of mine Jim Weaver (aka knobs) he put one in his brand new 70 z-28, after he put additional cooling on it, it worked good till the car was stolen from his home in lakewood,ca. But the hone knob and the 4 spd knob sticking out of the floor was a bit much. He also carried the stock driveshaft with him. I have 5 cars with gearvendor units they work fine,no extra floor shifts etc. Roger
  7. 38FLATTIE
    38FLATTIE
    from Colorado
    I looked at gearvendor, but decided to find an old Hone-o-drive.
    Anyone have the install instructions, or any info?
  8. squirrel
    Don't put too much torque to it...they can break
    Getting rid of the driveline vibration is the big problem. I guess it's not a problem if you mount it to the Ford rearend center section, like it was originally designed for. Hanging it off the back of a transmission with a U joint between the trans and OD is hard to get working right.
    It has a synchro...you can shift on the fly...if you have a clutch! putting an automatic in neutral doesn't work very good as a clutch.
    Speedo cable is fun too. Uses funky Ford stuff.
  9. 38FLATTIE
    38FLATTIE
    from Colorado
    You don't sound very impressed with these units.
    I was thinking of putting this between a 37 Lasalle ****** and a 3.54:1 posi Jag rear. Any other add on overdrives that anyone would suggest?
  10. squirrel
    see if you can find some 3.07ish gears for the rearend?
  11. 38FLATTIE
    38FLATTIE
    from Colorado
    That I can do. I just didn't want to lose that smokin' wheel spinnin':D ability with the flathead, if I could have both!
  12. squirrel
    You could try the Hone and see how it works. With an IRS you might be able to get the driveline situation under control, since the rearend does not move.
  13. I had half of one that bolted directly into a Ford 9 inch.The pinion was inside the back half of the unit. The gearing was 5:13's! I don't know what it changed to when the unit was put into operation though. It came out of an old Anglia drag car.Apparently they were used in Motion Baldwin cars so I'm sure they were able to take punishment....
  14. Left Turn
    Left Turn
    from Omaha, NE
    Baldwin Motion.....not Motion Baldwin....
    My uncle had one in a postal jeep... and had a roof rack on it for ladders and the driveshaft... That must have been a normal deal.....
  15. 38FLATTIE
    38FLATTIE
    from Colorado
    Thanks guys.
    If I can locate one, I'm going to try it.
  16. fanspete
    fanspete
    I've got one that's been adapted to the back of a Muncie, the tailshaft housing is welded to the Hone-O-Drive. Rosen used 'em in Motion's and ,I believe campers had 'em (that's a hint on where to find one!) so I'd imagine they're plenty able to handle some torque.
  17. Warpspeed
    Warpspeed
    I still have one of those around here someplace. They are either straight through (1:1) or in overdrive (0.7:1) I ran one with 3.89 gears, which works out to 2.72 in overdrive. The type that fits onto the front of a standard Ford 9" diff has zero vibration problems.
  18. 61bone
    61bone
    Rather have you mad at me for not selling it to you than for selling it to you.
  19. 38FLATTIE
    38FLATTIE
    from Colorado
    That's good info, thanks.
    Well, the '38 has a ford 9" in it now, and I'm still looking for one.....:D
  20. Warpspeed
    Warpspeed
    I will see If I can dig it out from under all my other junk and take a look at it. It has been at least thirty years since I last used it. Problem is, Colarado is kind of a long way from Australia.
  21. 38FLATTIE
    38FLATTIE
    from Colorado
    Can't blame me for trying!
    Oh, not that far! On my '38 build, I have quite a few parts that were custom made in Perth, and more on the way. The hone-o-drive is also for the '38
  22. Warpspeed
    Warpspeed
    There are two different types of Hone overdrive. This is the less common type, that is a straight bolt-on onto any Ford nine inch diff. Any ratio 9" pinion fits into this overdrive, and the overdrive fits where the original pinion carrier fitted, using the same pinion depth shims. There is a shift rod next to the drive flange that shifts from direct drive, to overdrive. The hole at the back is for the speedometer drive gear, which runs direct off the pinion shaft. That way the speedometer reads correctly when either in direct or overdrive. This type of Hone overdrive does not suffer from the same vibration problems that are common with the more usual unit that sits in the middle of the tail shaft. [​IMG] [​IMG] http://www.stangerssite.com/honeodrive.html
  23. 38FLATTIE
    38FLATTIE
    from Colorado
    This does look like a better option than the universal drive. Sounds like this would take care of the vibration problems talked about above. <!-- / message --><!-- sig -->
  24. Motochris
    Motochris
    I have one of these going on Ebay tomorrow.... starting bid at $999 if anyone is looking for one.
