Escaping blower belt
Discussion in 'H.A.M.B. Drag Nationals' started by zrdtech, Aug 21, 2012.
  1. zrdtech
    zrdtech
    from Montana
    I accidentally caught this blower belt coming loose during a burnout. Can't remember who's it was, but thought I should post it here. It was my first HAMB Drag. Had a ball! I have the full-size image if someone wants it.
      475.3 KB
  2. Malcolm
    Malcolm
    from Nebraska
    That's Kerry..
    Cool photo! Hopefully he can get it sorted out. I have no doubt he will...
    Malcolm
  3. squirrel
    I heard about him throwing the belt, but never thought I'd see a picture of it in action! great timing
    Now, to figure out what's causing it.....
  4. Rob3865
    Rob3865
    He needs to be more careful about keepin that belt prisoner.
  5. redlinetoys
    redlinetoys
    from Midwest
    Great shot! Looks like the guy in the middle could have been wearing that belt around his neck!
  6. Kerry
    Kerry
    Yep, that's me and my wayward belt. Awesome picture!!!! Thanks!!
    Each time as I got off of the throttle it jumped. I did a bit of playing with it when I got home and watched it move back and forth as RPM changed. I think I need some more crown on my homemade idler pulley. That and tighten it up a bit.
    If you look at the tank you can see Tuck's video camera. He said the video of it coming off is great. I would have rather he say the video of the p*** was great but I'll take it as another tool to fix the ****er.
  7. squirrel
    How much free play does the belt have when the engine is cold? I run about 3/4" deflection from straight.
  8. Kerry
    Kerry
    Roughly that. It never warms up to grow until the p*** though. That alchy runs cold.
  9. squirrel
    I don't think my idler pulley has any crown on it.
    Could the idler be misaligned? how straight is the intake?
    It just seems strange to me that you're having trouble. I've put over 100k miles on my blower motor, never lost the belt
  10. Kerry
    Kerry
    It doesn't appear missaligned but it's kind of hard to measure. At idle it centers, RPM accelerating it moves back and decel it moves forward.
    I've seen flat idlers and some that have almost .100 over the width of the 3" idler.
    What pitch and width of belt are you using? This is a 1/2" 2" wide.
  11. jody1833
    jody1833
    Hey Kerry, regardless the car is way cool. Sure enjoy seeing it.
  12. squirrel
    Mine is 3" wide 1/2 pitch.
    The wear on my pulleys indicates it stays at the back all the time.
    Careful checking with a straight edge on the front faces of the pulleys should be able to tell you if it's aligned.
  13. ryno
    ryno
    Could it be something flexing that causes this? Or bearing run out?
  14. squirrel
    The idler mount could be flexing. The snout should be pretty stable, if it's built properly. The crank snout should also be plenty stable on that engine.
  15. daschaefer
    daschaefer
    Belt may just be stretched on the fwd or aft side. Try installing it 180-out to see if it changes the directions that its creeping when you accelerate/decelerate...???....
  16. Kerry
    Kerry
    I'd like to play with it tonight and figure it out but I've got some other stuff to do. Swapping it 180 is a good idea. I have a whole two p***es on the new belt before it jumped. :-/
  17. squirrel
    I kinda doubt it stretched in two p***es, unless it was adjusted too tight?
  18. Kerry
    Kerry
    The consensus from some racing friends is that I've been adjusting it to loose. I'll check for true tonight.
  19. flamedabone
    flamedabone
    Kerry, do you have a pic of your idler bracket ***y?? Also, if the car never gets hot, you should maybe try 1/4 flex instead of 3/4...
    Try running it up to McDonalds and back then check it.....
    -Abone.
  20. squirrel
    I was gonna suggest running it down the quarter mile and see how tight the belt gets...but that ain't gonna work is it?
    Try half inch, my guess is 1/4 inch is a bit tight. Something about sines and cosines
  21. infoleather
    infoleather
    from New York
    It just seems strange, I think you're in trouble. I have my blower motor more than 100 thousand kilometers, and never lost the belt..
  22. Kerry
    Kerry
    No, I was in Missouri. This is no street engine. The speed that it gains and drops RPM with the Hilborn is nothing short of amazing. It doesn't like the deceleration. I'm convinced the biggest issue is that I have had the belt to loose. Alignment looks ok. I'm going to find a better way to measure tension, cinch it up, and do some more testing.
  23. jody1833
    jody1833
    Kerry, I run mine ultra tight! I know that is not very technical but I use a tool intended for something else to get leverage and go for it when I tighten it. I have never had any belt drive problems or lost a belt. As you mentioned, this is not in the same department as street driven and needs to be treated as such. I have seen a lot of belts placed on race machines and never once saw them measure flex or tension.
