I'm coming up blank. Do you know for sure? It says Nash, but there's a question mark so the seller isn't too sure either. By earthshaker5769 at 2012-08-23 By earthshaker5769 at 2012-08-23
My guess is it's for a Ford 6 cylinder. The intake is cast onto the head and this would be the only way to add extra carbs. my2¢ your may vary?
Yeah, if you're thinking the 170-200-250 six, that's not it. I don't know either, but there were some '50's flat sixes that used intakes like this. Later, *****6
the healy version of the Nash engine, with side drafts and a huge image of a stock 1bbl engine http://www.precisioncarrestoration.com/wp-content/uploads/2012/03/P3070378.jpg
Huh, learn something new every day. Thanks guys! I love vintage speed stuff.this is on eBay right now if anyone is interested. I do not have any Nash motors to grace it with.
If that fits the particular Nash engine that I think, it has even a weirder exhaust setup.. The manifold is actually just an exhaust pipe, mounted along the side of the block. Kind of like a Flute on the block It has cradle shaped saddles around the ports, for the pipe to lay on.
