1952 Ford F1 daily build
Discussion in 'The Hokey Ass Message Board' started by THR1LL3R, Jul 26, 2012.
  1. Magnum Wheel Man
    Magnum Wheel Man
    I was thinking of mounting my shocks ( this is a Studebaker, not a Ford, but similar design, & finished result expectations ) on the front frame notch up & using the old spring pad for the bottom of the shock mount, & fabbing a shock mount on top of the notch...
    I have to bend my p***enger steering arm off my spindle to clear the 12" Caddy brakes I'm going to run
  2. jfrolka
    jfrolka
    Looks like 670-15 up front and an 810-15 out back
  3. hopped up
    hopped up
    from So Cal
    looking good! keep us posted.
  4. THR1LL3R
    THR1LL3R
    from St. Louis
    Steering box mock up, probably gonna need to tilt it back a few degrees
  5. THR1LL3R
    THR1LL3R
    from St. Louis
    rear perch step
  6. THR1LL3R
    THR1LL3R
    from St. Louis
    Stripped 6 layers of enamel of the firewall giving Aircraft stripper a run for its money. [​IMG]
    poor neglected shoebox :(
  7. lodaddyo
    lodaddyo
    Looks really good man! I need another project:)
  8. monster
    monster
    its goin to make one sweet daily driver!
  9. eightbanger
    eightbanger
    That truck rocks. I'm dying to get my hands on one soon! Love it.
  10. willie57
    willie57
    from wisconsin
    great looking truck, love those early 50's trucks.
  11. Tha_PiG
    Tha_PiG
    from Georgia
    Nice.
    Subscribed.
  12. barrnone50
    barrnone50
    from texas
    That is one sweet truck. On the lower rear shock mount did you cut part of it off and just use the stud end ? great job on the build now I need to get off my *** and finish my f1.
  13. THR1LL3R
    THR1LL3R
    from St. Louis
    You could probably just use the whole thing and make it completely flat,wish I would a done that instead.
  14. JasonHehn
    JasonHehn
    Great build thread. Hope you don't mind if I steel a few of your ideas for my F1 panel build. Subscribed!
  15. THR1LL3R
    THR1LL3R
    from St. Louis
    gofer it!
  16. THR1LL3R
    THR1LL3R
    from St. Louis
  17. THR1LL3R
    THR1LL3R
    from St. Louis
    Modified stock xmember for c4 mount
    Got me some blockhugger headers but still gonna have to move the steering box back a 1" or 2"
    got me some 15x7's out back
  18. Dreddybear
    Dreddybear
    Awesome so far. If I can add one thing I'm sure you already know, please gusset the **** out of the steering box mount. Can't wait to see it back together!
  19. barrnone50
    barrnone50
    from texas
    Any updates on your ride? I was looking at the rear notch you did to see how that worked out for you. I have seen some that notch about 6-8 inches above the top of the frame rail, I dont think it has to be that high, yours is what I will probally do if you don't mind taking your idea. I have also seen taking a half round steel pipe and using that. Look forward to your progress:D
  20. dellyjonut
    dellyjonut
    from St. louis
    Subscribed, now you have the custom, hotrod and pickup.
    Sent from my DROID device using the TJJ mobile app
  21. lucky ink
    lucky ink
    It's gonna turn out cool..Love those 52's
  22. THR1LL3R
    THR1LL3R
    from St. Louis
    You can use steel pipe,I was too lazy to cut a circle. I didn't go too high still want to use it as a truck and not have a big notch and rear-end taking up the middle of my bed. :D
  23. THR1LL3R
    THR1LL3R
    from St. Louis
    Speedway front disc kit
    How it sits now...G78 front L78 rear
    Cut 5" of the steering column and rod down,slugged and rewelded
    Nice and far away from my face...lol
  24. THR1LL3R
    THR1LL3R
    from St. Louis
    Now on to the fun part..Speedway custom exhaust kit,cut up collectors off my old mustang h-pipe and a headman crossover all migged together
  25. freeflynstl
    freeflynstl
    All this cool **** happens on the Southside and I didn't know it.
    Nice work on a neat project. Glad to see other good stuff happening in South STL.
    Andy from STL
  26. Johnny Wishbone
    Johnny Wishbone
    Does it run yet? Hurry up, I have a couch I need you to move for me.
  27. barrnone50
    barrnone50
    from texas
    Super Clean Exhaust ..You make it look so easy.
  28. 53olds
    53olds
  29. THR1LL3R
    THR1LL3R
    from St. Louis
    Cleaned the brakes up and running new lines with the Mustang master cylinder. Ordered the kit from ECI and would have just put the kit together myself if I knew the bad customer service I was gonna get.
    bought 1987 Jeep wrangler wheel cylinders which are exact replacement for the stockers
