Are these the right caddy hubcaps
Discussion in 'The Hokey Ass Message Board' started by 220, Aug 24, 2012.
  1. 220
    220
    from so cal
    A guys selling these for 400 are they the right one everybody uses he said their off a 56 caddy thanks
  2. junk yard kid
    junk yard kid
    Ill take 200 for my set. i dont think those are the ones everyone wants, you need a deep wheel for them.
  3. the-rodster
    the-rodster
    Cad caps 49-57 are ALL desirable.
    Just depends on the look you are after.
    Rich
  4. Those are definately hats but 100 bucks apiece seems a little steep to me.
  5. Dward57
    Dward57
    They are indeed '56 caddy. The caddy caps seen most often are '57. but the-rodster is correct. They are all good it just depends on what look your after.
  6. 58 Yeoman
    58 Yeoman
    from Lacon, IL
  7. U-235
    U-235
    Sorry, but those are NOT the 57 Caddy caps everyone uses....they are later (not sure the year) and will not fit anything but a Caddy as they are way to deep..!
    They're not worth anything except to the correct year Cadillac owner. Don't even conseder them.
  8. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Those are 56 Cad caps, but don't use those, they're almost impossible to make a wheel that fit them and your car unless you have tons of fender clearance
  9. gasmanm01
    gasmanm01
    i have a full set that im asking 400.00 for. you cant just run out and find th:Dem anywhere.
  10. robyyo
    robyyo
    from Orange CA
    Those are 56 Caddy, and yes you need a deep dish wheel for them to work. I've got a set if you need them. $400.00 seems too high for those.
  11. U-235
    U-235
    I'm going to have to reconsider my first reply. They do look like 56 Caddys and not later model as I erroneously stated. Still, they are not desireable and "the-rodster" is incorrect (sorry rodster) as the 55-56 caps are NOT what people are putting on their cars because they are so deep. What most people use are the 57 caps, as for some reason, they are shallow, and the pre 55 caps known as "Sombreros" for older customs. Hopes this saves you some money and heart ache.
  12. 220
    220
    from so cal
    OK SO ITS 57 CAPs EVERYBODY USES THANKS GLAD I DIDNT BUY THEM if anybody has a show qualty set p/i me thanks again guys
  13. 220
    220
    from so cal
    How about these ones are the right hubcaps everybody use guy want 400 thanks
  14. Saxon
    Saxon
    from MN
    Those are cool. But wasn't it about taking caps that were not cool and making them... kool?
    Ugh where is the official hamb hubcap thread!?
  15. 220
    220
    from so cal
    I just want start with the right ones the first photo turns out 56 high ones again r the second photo 57 the right ones to start with
    thanks
  16. sumner41
    sumner41
    those caps are 61 caddy
  17. 220
    220
    from so cal
    The 2nd photos are apost to be 1957 ones ,the ones most use if am wrong plesae let me know befor i buy them thanks
  18. damagedduck
    damagedduck
    from Greeley Co
  19. Saxon
    Saxon
    from MN
    I don't know what wheel your using but remember deep dish caddy caps require a off set wheel.
    Thanks DamagedDuck
  20. I've been carrying a pair of them around for about five years for $50 for both. I've had one nut try to buy just one about three times, he thinks I don't remember him but I do. Now if you need one, why not buy a spare in case you lose another?
  21. damagedduck
    damagedduck
    from Greeley Co
    DEEEEEEEEEEEP rims for sure! i had mine on 10' wide rims (don't ask!)
  22. Ester Eddie
    Ester Eddie
    from Alaska
    My 56 has these smaller ones that fit in the center of the rim.
    [​IMG][​IMG]
  23. damagedduck
    damagedduck
    from Greeley Co
    In your 1st question/post you showed the deep Caddy caps,& we mentioned your gonna need deep rims here why....(i forgot i had these)$400 for caps that aren't new way too much! just my 2¢ ...
  24. Skirv
    Skirv
    Those are indeed 57 Cadillac caps. You don't need a really deep wheel to use them.
  25. Mr48chev
    EXACTLY!!! They only work on the wheels they came on and even then are a royal pain in the *** to get on right. You have to use special wheel weights and hope that everything works right.
    400 sounds way too high unless they are absolutely perfect NOS in the factory boxes and you need them for a 100 point restoration.
    Real 57 caps will fit on most wheels and that is what most guys run that don't run sombreros as far as caddy wheels go.
    When I put the 57 caps on my 51 Merc I hunted them down one at a time at swap meets and picked them up for quite a bit less than the asking price for a set but these days you probably would be right behind the guy buying them up to put them in sets and triple the price.
  26. 220
    220
    from so cal
    thanks everyone
  27. Ester Eddie
    Ester Eddie
    from Alaska
    Are the caps I posted 56 ? They came with the car but I never really thought about it before .
  28. Cortney
    Cortney
    I've been told that the Cragar square "D" style wheels will allow for the 56 Caddy caps to fit, but I've never tested that theory. Square D's are pretty cheap and can be bought new for almost any application. Just a thought. $400 is way to much in my opinion. I have a set that can't sell even at $50! Make great wall art though!
  29. JayD
    JayD
    Those are cool......................and not so deep. I'd use 'em!
  30. I looked on eBay after I posted out of curiousity and you could buy a complete set there for $80. The $400 seller probably doesn't know what he has.
