Coolant Recovery Puke tank
Discussion in 'The Hokey Ass Message Board' started by divco13, Aug 20, 2012.
  1. What do you use for a Coolant recovery tank. Picture's please.
  2. -Brent-
    -Brent-
  3. Deuces
    Deuces
    No pic of one, but how about a Moon fuel tank???..;)
  4. olds vroom
    olds vroom
  5. A nice old milk bottle!
  6. jimmy1931
    jimmy1931
    Eelco Tank ( like Moon )
      4.4 KB
  7. DrJ
    DrJ
    I used a Black plastic bicycle water bottle.
    Lousy color for a drinking bottle, unless it's to keep your tea hot.
    Works great and fairly incon****uous under a hood.
    I drilled out the "******" and stick the overflow hose in it to the bottom.
    I cut the end of the hose on a slight angle so it can recover fluid without just suctioning itself to the bottom of the bottle.
  8. squirrel
    I just put this on a couple weeks ago.
  9. mechmitch
    mechmitch
    Jagermeister bottle. Cheap, plentiful, and already green
  10. OLDSMAN
    OLDSMAN
    On my convertible, I use a tank from a Ford Ranger pickup, from the early 90's. It also has the washer tank in the same unit. I used this because the vert had factory windshield washers on the car. This whole setup works great
  11. bobss396
    bobss396
    We used to grab anything out of a junk car as well. Almost always free and easy enough to adapt in. On the stock cars, we'd use gallon cans, the type with the screw on lids.
    Bob
  12. unkamort
    unkamort
    I used a small propane bottle. A piece of brake line was routed downward from the vent hole after this pic was taken. Disclaimer: This thing had been laying around empty for years... but there is ALWAYS a chance that some residual fuel is still in there!
  13. A used douche found in a Fifth Ward dumpster.
  14. el Scotto
    el Scotto
    from Tracy, CA
    Hahahahahahahahaha!!!!!!!!! :D
  15. An expansion tank for my 27. It's made from a fuel pressure reservoir off a Huey and mounts on the spring hanger for the front suicide axle on my Modified using airframe clevis joints from a DC3. It's fitted with a Stant cap and Moon direct temp gauge.
    After polishing
    Before
  16. 40FordGuy
    40FordGuy
    Window washer tank for mine.... One from a 2000 F150 holds a gallon,.... And so does a Prestone container...... A G.I canteen would be different........Likin' the Moon tank !
    4TTRUK
  17. n847
    n847
    I use a coolant recovery puke tank...From Jegs
  18. R Frederick
    R Frederick
    from illinois
    An old br*** fire extinguisher.
  19. slddnmatt
    slddnmatt
    another old Pyrene that I chopped down a few inches
  20. BLUDICE
    BLUDICE
  21. MRTS33
    MRTS33
    Cl***ic!;)
  22. Keep
    Keep
    I used a brush stainless steel water bottle. You can just see it here in the pic.
    Paid $3.57 on clearance.
    Those fire extinguishers are outstanding!
  23. Gas_Tires_Oil
    Gas_Tires_Oil
    An old Keg made into a puke tank.
  24. How much liquid should it hold? Typical 40's flathead
  25. blue 49
    blue 49
    from Iowa
    Mine, made from aluminum electrical conduit. I had endcaps tigged on and then turned the whole thing in the lathe to give it a finished look. It holds about a pint.
    Blue
      194.2 KB
  26. ct1932ford
    ct1932ford
    Antique Squeeze soda bottle:cool:
  27. 19blockhead72
    19blockhead72
    I don't have a picture but I use a modern plastic Ford tank but instead of putting it under the hood I hid it behind the front bumper on the bumper brackets. I can check it easy and it's out of the way.
  28. ScottyVenture
    ScottyVenture
    So do these tanks **** the fluid back in when needed?
  29. 53sled
    53sled
    from KCMO
    Monster BFC energy drink can. 32oz I think, going on 5 years now.
    For a reliable driver, at least a quart capacity, but you only NEED half of that. It has to puke out and **** back in, so it must be vented.
  30. Army Canteen.
