The motor... a 327 built in 1964. (PHOTO INTENSE)
Discussion in 'The Hokey Ass Message Board' started by DHeep, Aug 26, 2012.
  1. DHeep
    DHeep
    So this marks the start of my motor education and planning. I will start by posting a few images of what I have, then I'll post what I think I know about it, and what I believe should be my path forward.
  2. DHeep
    DHeep
    More photos.
  3. DHeep
    DHeep
    Last photo.
  4. Mr48chev
    those are some serious valve reliefs in the pistons. No problem with the valves hitting the pistons due to a big cam.
  5. Atwater Mike
    Atwater Mike
    Any relation to Uriah?
  6. DHeep
    DHeep
    I have always been a 4-Stroke fan. I love torque and low end power. That being said, I'm looking at an Idle-5500 or 1500-6500 motor built.
    Trick Flow heads with Edlebrock cam, intake and carb have been suggested to me.
    As I browse parts on Summit Racing, I notice how widely varied the prices are. Should I splurge for the most expensive parts? How much of a difference is there, and how do I know what level of part I should go with?
  7. DHeep
    DHeep
    The KB rep told me they are +7cc.
  8. DHeep
    DHeep
    Are you talking to me?
  9. Ebbsspeed
    Ebbsspeed
    What that means is, when you do your compression ratio calculation, in addition to the cc volume of the cylinder head combustion chamber, you must add 7cc to that number, because that's how big those valve reliefs are. There will also be a "cc" number that you need to include, depending on the thickness of the head gasket
    Yes he is. Uriah Heep may well have come and gone before you were born. Ever read Charles ****ens "David Copperfield" or listened to old English rock bands?
  10. DHeep
    DHeep
    Here is what I believed to be the piston specifications while thinking I had a 383:
  11. DHeep
    DHeep
    Sorry, no tie to Uriah.
  12. Ebbsspeed
    Ebbsspeed
    That could be a 302, a 327, 350 or a 383. Can you measure the stroke and let us know what it is? 3" is a 302, 3.25 is a 327 and 3.5 is a 350. If the stroke is 3.75 then you've got a stroker 383.
    The spec sheet you posted says a 6 inch rod. Are there any visible numbers or other ID on the rods that you can see? KB makes the same piston for use with a 5.7 inch rod, which is the stock length. I don't think there were too many 6-inch rod SBC motors built way back in 1964. For that matter I don't think those pistons were available way back then. How do you know this motor was built in 1964?
  13. bobwop
    bobwop
    from Arley, AL
    I like the Uriah reference
  14. DHeep
    DHeep
    Difference in height between TDC and BDC is 3.25".
  15. DHeep
    DHeep
    Ok, I know the photo of the manual above doesn't apply, because it's not a 383. Here is what I found on the KB website:
    http://www.kb-silvolite.com/kb_car/performance.php?action=details&P_id=46
    Compression Ratios
    58cc-10.4
    62cc-9.9
    64cc-9.7
    76cc-8.5
    Ring Packs
    2-1/16
    1-3/16
    Ring Sets
    4000BD8
    Pin Number
    0927x300K
    Lock Ring
    PRJ100-3
    Effective Head Volume: 6cc
    SPECIFICATIONS
    Bore: 4.000
    Rod Length: 6.000
    Pin Diameter: 0.927
    Stroke: 3.250
    Comp. Ht: 1.385
    Sizes: STD
    .020
    .030
    .040
    .060
    Minimum Clearance:
    SPECIAL CLEARANCE REQUIREMENTS
    Crank-to-Deck Clearance: 9.025
    Weight: Piston / Pin: 485 / 145
  16. slammed
    slammed
    CAMSHAFT? That will will help w/ head selection. What is the intended vehicle? And Uriah was an excellent band. An acquired taste.
  17. DHeep
    DHeep
    The intended use is as the power plant for my 2R5 pickup. Cruising around town,
    yearly road trip to Hot August Nights, etc.
    I was looking at Edelbrock 2210 - Edelbrock Rollin' Thunder Hydraulic Roller Camshafts.
    http://www.summitracing.com/parts/EDL-2210/
    However, I was looking at:
    Trick Flow Specialties TFS-K314-420-395 - Trick Flow® 420 HP Super 23® Top-End
    Engine Kits for Small Block Chevrolet, which comes with a cam.
    http://www.summitracing.com/parts/TFS-K314-420-395/
    <style><!--table {mso-displayed-decimal-separator:"\."; mso-displayed-thousand-separator:"\,";} @page {margin:1.0in .75in 1.0in .75in; mso-header-margin:.5in; mso-footer-margin:.5in;} td {padding-top:1px; padding-right:1px; padding-left:1px; mso-ignore:padding; color:black; font-size:12.0pt; font-weight:400; font-style:normal; text-decoration:none; font-family:Calibri, sans-serif; mso-font-ch****t:0; mso-number-format:General; text-align:general; vertical-align:bottom; border:none; mso-background-source:auto; mso-pattern:auto; mso-protection:locked visible; white-space:nowrap; mso-rotate:0;} --> </style>
  18. 56sedandelivery
    56sedandelivery
    Small journal 327, forged crank, aftermarket rod bolts, and the already mentioned KB pistons; that's what I see. Hard to tell if it's been balanced, but the balancing pads on the big end of the rod look untouched I did'nt actually plan it this way, but I have THREE, 327's, a 350, and a stroker 305 (334 CID). Nice start. Butch/56sedandcelivery.
    The rods look stock, not aftermarket 6 inchers; are you sure you have the right KB part number?
  19. kyvetteman
    kyvetteman
    That's funny right there!:D
  20. I wondered how long it would take for him to get it...... kid's.
  21. PackardWood
    PackardWood
    from JoCo, NC
    How much is it bored over?
  22. DHeep
    DHeep
    Sorry, I am THE worst at names of actors, musicians and bands. Just not my thing.
  23. DHeep
    DHeep
    It's 30 over.
  24. DHeep
    DHeep
    I seem to have missed a lot of questions.
    I know the block is a 64 by the cast number. The pistons and crank happened a few years back when dad started the project.
  25. DHeep
    DHeep
    So what are the thoughts on these? Any input on cam, heads, or intake?
  26. Mr48,
    This is not a scare type of post just information. I had a set of Keith Black pistons one that the valve reliefs were not in the right place, either I had goofy heads or they were not machined correctly, the intakes hit the edges of the reliefs and I had to open them up a bit. I check every set any more no matter who bulds them or how deep the pockets are. ;)
    Mr deep nice looking short block by the way.
  27. DHeep
    DHeep
    Thank you sir. I am dying to get this thing running. I want to drive it!
  28. DHeep
    DHeep
    Ok, question for the hive...
    I am looking at motor placement, and thinking that having the headers for mockup will be beneficial.
    So now I must ask, anyone have header suggestions? Flowtech? Short, mid, full? I'm thinking the money for the ceramic coating would be well spent.
    I see all these different models of headers that are vehicle specific, but obviously the 327 wasn't a Stud option, so it seems to be a guess as to which part to buy.
  29. Model A Vette
    Model A Vette
    3782870 casting is for 62-65 327 originally.
  30. DHeep
    DHeep
    Thanks Ed... I've got the date and block figured out. Now it's about exhaust selection.
    Back to Google for me... If it's on the internet, it HAS to be true, right? LOL
