Projects 49 Plymouth Chop/Sedan to Hardtop-
Discussion in 'The Hokey Ass Message Board' started by choprods, Aug 10, 2005.
  1. I am posting this for the Plymouth Dodge guys to show a way to improve the look of an otherwise -shall we say -HOMELY car:) ....sorry- but thats the rep they got.
    I 'll post one before pic to show the profile.
    This car is our buddy Matt's[TankWilson] here on the HAMB.
    I was given a free reign to do what I felt was in order to give the old car a facelift of sorts.
    I decided to follow his hint:D and do a more severe chop rather than the ordinary 2-3"er Ive saw on these cars.
    The roof line on these about ruins an otherwise cool old car.they are also relatively easy to find and seem to run well with the original drivetrain .
    But yet they are not well accepted over say a shoebox Ford or 49-50 Chevy car......
    If they can be improved Id say stance and a chop are in order.
    The plan is to lower the back some more like a taildragger look after I am done with the Top surgery.
    These shots are all of it at its current height -although it has 4" blocks it can stand some more lowering........
    I decided on 7" at the windshield and then went with 8" at the rear of the quarter gl***......
    I removed the stock rear gl*** and opening and re installed them about 5" further forwards in an effort to visually lengthen the trunk some.....
    the Hardtopping consists of cutting out the B pillars and removing the frt door tops THEN welding them to the drip rails .
    I then installed a chunk of the old door top from its vertical part in place of the area that used to be the corners of the door anmd quarter gl***es.....
  2. some pics
  3. front of door top and hardtop reconstruction.....at the B POST TOO
  4. No_Respect
    No_Respect
    from So-Cal
    Is there any more pictures? I love 50's mopars they are not the "in thing" but that makes them cool the lines are ***y once you smoth them up a bit!!
  5. side
  6. southpaw-customs
    southpaw-customs
    Wow, that does make a difference. Nice looking chop and car.
    morebel
  7. Slide
    Slide
    Definitely an improvement. Good call on taking that much out, and moving the back gl*** forward.
    What's the plans for gl*** and all? Are ya keepin' the vent windows? What about the "trailing edge" of the door gl*** (where the B-pillars used to be)? Izzit gonna be angled or curved or straight vertical? IMO, it's beggin' for a slanted curve a-la Hirohata Merc (or Matranga Merc).
    With no gl*** at all right now, the window opening looks too long, but that top profile is soooooo right. Keep us posted on this... it's gonna be a kool one!
    My dad and I chopped the top only about 2.25" on his 51 Plymouth Business Coupe, and man, what an improvement!
  8. 55olds88
    55olds88
    Kool chop, makes the back end look a whole lot nicer, more 46-48 Ford/Merc rear look from the side rather then the too squat rearend it had stock, I'm liking it :)
  9. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    nice chop. It does look much better, the lines are perfect.
    As said in a previous post, it gives it a Ford/Merc Coupe look in the rear....almost like a taildragger.
  10. Radshit
    Radshit
    What can you do about that ugly ***-end....it's so........so....Big...hehe
    Nice lines on that chop, that's why you are the pro!
  11. cool... post more pics, too. I'm working on a '50 dodge, I'd like to chop it someday, a little different, though.
    Before:
    Now:
    Someday:
    Another option for a chop would be grafting a 50's chevy top on it like this:
    50's mopars do have potential, you just have to find it....
    Thanks for posting!
  12. J53
    J53
    from WI
  13. The chop is looking great. I've had my eye on one of these for awhile. It needs to be rescued.
    I figured out what looks wrong with these old Mopars. The wheelbase is too long. The space between the rear fenders and the back of the door is too big. I did this simple fix on a Paint program. Moved the rear wheels forward maybe five or six inches. I think it looks a bunch better already.
    Dan
  14. Forget ****ing with the wheelbase... just slam it... everything looks better slammed...;)
    oh, and here's another chopped plymouth:
  15. BloodyKnuckles
    BloodyKnuckles
    Oh, I will definately follow this thread!
    See what I mean?
    Thanks for the info and pics. They are greatly appreciated!
    ******Knuckles
  16. roadsterpilot
    roadsterpilot
    Great top, Kenny does awesome work, he can turn a sows ear into a silk purse. I cant wait to see it around town......RP
  17. Im back-Tonite is my wifes birthday and we went out for supper and shopping.....
    The above cars are cool but in my opinion the top HAS to be shortened in length and somehow the trunk needs to LOOK longer....Thats what we achieved easily on Matts car by moving that rear window forwards and adding a filler panel between the trunk lid and the slanted gl***....The dodge [white] already HAS about a 6" shorter roof than a Plymouth does,as well as slant post in the B position..
    Another trick ya'all missed is the fact that I left the rear corner of the quarter gl*** pointed.....ALSO I trimmed the rounded corner of the FRONT end of the door top to match.....makes the C post look slimmer........
    When hardtopping it like I did this one you have to do this or if not you end up with the sharp point of that same corner sticking in your face when you open the door from under it-:eek: might tear your tutu on that bad boy!
    ALSO a lot of lowerin needs to be done on these cars
    In answer to the gl*** question -I will put a bottom support BELOW the quarter gl*** and install it by sliding it in and out.
    I t will have a seal strip [angled] between it and the door gl***.
    The door gl*** is a whole different can of worms...it will need to be in a position that allows it to be all the way up and yet allow the door to open and shut without moving the gl*** up and down.
    This will be accomplished by sealing off the groove in the door top where the channell run USED to set. then a 1/2" 90 degree lip is installed at the INNER edge to mount an L shaped gasket much like a real hardtop has to seal and support the gl*** and still allow door to open and close with gl*** rolled UP....
    Also it will be necessary to increase the HEIGHT of each door gl***......say if the side window opening is 7" tall I will cut the gl*** 12" tall.
    This will allow the vertical channels in each end of the doors to steady/support the gl*** even when partially up or down-If you did not do this the door gl*** would **** outwards at speed and leak or break....
    the angle of the door gl***es travel is also going to be steeper than it was stock to compensate for the change in the roofs new shape/angle.
  18. tankwilson
    tankwilson
    Me too.
  19. sawzall
    sawzall
    SAY IT ISNT SO.. I have one of those in my driveway right now! its here for a motor and trans swap.. almost done with it till the owner gets the real motor to me..
    apparently these Mopar's are the upcoming thing. I know someone else whos going to look at one on sunday..
  20. tankwilson
    tankwilson
    Looks great kenny. Not trying to take this thread in a different direction, but I have been thinking about putting in a different grill once i lower it and do some other mods. Anybody got some cool pics of grills. Don't really want to put in a stock grill from another car... not trying to make it look like a chevy, ford or merc, but do want more of custom look for the front. Anyone got any pics.
    Thanks
    matt
  21. blueskies
    blueskies
    from Idaho
    The chevy roof grafted on would be killer. I think the stock roof line is too flat across the tops of the doors and rear windows, and the rear gl*** is too steep. When chopped, the roof looks even flatter to me.
    Here's my '50 Plymouth, stock body and all.
    Pete
  22. Heres a few more shots for perspective-OUTSIDE......I pushed it out and sanded it bare then the 100 degree sun and 95 %humidity forced me to take a break!
    its so hot ya can't touch it now....;) .
    The tires are taller than I think they need be and it needs some ch***is SLAMMIN!:D
  23. front and side-
    Sawzall-your car there is a bus coupe and has a 6"shorter roof than a sedan [like this one].....
    These kinda remind me of cars from the old 40's cartoons with the stock appearance and ride height.....:eek: CHOP EM...:D
  24. tankwilson
    tankwilson
    WOW. Looks even better outside. Take a break ... Don't have a heat stroke because of me.. i wouldn't be able to sleep at night..... probably won't now that i see it again.
    Thanks
    matt
  25. tankwilson
    tankwilson
    I tend to agree now. I really like the looks of the wide whitewall and bias ply. Do they make a shorter and squatier (is that a word) tire that is like the ones it has now. What tire would you put on it now??
    Thanks
    matt
  26. RocketDaemon
    RocketDaemon
    from Sweden
    huge improvement on that car, looks good
    one thought though, the licence plate need to get moved down to the bumper, would clean up the decklid alot, the licence plate kinda takes to much attention and irretate the lineflow...
  27. RocketDaemon
    RocketDaemon
    from Sweden
    i like those early mopar coupes/2door sedans, they look like they still got plenty roots in the late 40ies and still early fifties, like take an 46 coupe and an 1952 car and morph them...
  28. Gasserfreak
    Gasserfreak
    from Yuma, AZ
    Great looking chop. I was looking at one of these not to long ago after I sold the coupe, I just couldn't get past the "bubble ****" on those old dodges. Mabe a wedge section from front to rear would help out the look a bit, maybe just section the trunk lid, I'm not sure. I never could come up with a good way to get it looking right, maybe if I was a little better a photo chopping I'd own one of those now instead of the Vicky. Good Job though man it did wonders for that car.
    Drew
  29. haha aint it funny we no sooner get home from your house and this thread is up, coincidence...i think not
  30. mexicano
    mexicano
    Nice work .... if you ever consider going into the plastic surgery field ...damn....I lost it there for a minute...I agree on the license plate thing and maybe sectioning the trunk to lower its profile would make it look better....but I don't know ****.....now about the other thing ,you know you don't have to be licensed to practice right.. :D
