are 302 ford and 351W distributors the same
Discussion in 'The Hokey Ass Message Board' started by hmuchler, Aug 28, 2012.
  1. hmuchler
    hmuchler
    I need to know if the Ford 1970 302 and the 351W Distributors are the same, are they interchangeable?
  2. can't swear to it but I think the 351 is longer, Now that I reread this, I guess I did not help much.
    Sorry
  3. Kenneth S
    Kenneth S
  4. 65 Hemi Coronet
    65 Hemi Coronet
    from Florida
    No, they are not. The 351 is longer, the block is has a higher deck height. I'm building a Dart windsor based block, bored and stroked to 454 right now....
  5. BurnoutNova
    BurnoutNova
    from USA
    Yep 351w is sure longer!
  6. wingedexpress
    wingedexpress
    I think 351 has a larger oil pump drive also
  7. hmuchler
    hmuchler
    Better to find out before I tear it out.Thanks. I sure can count on the HAMB members.
  8. hotroddon
    hotroddon
    Not only longer but different oil pump drive diameter as well.
  9. Deuces
    Deuces
    Yep!... A 5/16" hex drive to where a 289/302 is only 1/4" hex...
    Ever see one of those twisted???....:eek:
  10. Deuces
    Deuces
    The Windsor distributor body is also beefier below the block mounting face..
  11. hmuchler
    hmuchler
    Thanks for the help. I and I was able to replace my diz.
