yellow white wall tire how to fix?
Discussion in 'The Hokey Ass Message Board' started by wallyringo, Aug 28, 2012.
  1. wallyringo
    wallyringo
    I have a set of radials with the 1 inch white walls, 3 are nice and white and one is yellow, after i cleaned that blue **** off i notice it was yellow. is there anything to clean it or is it a bad tire?
  2. 56don
    56don
    I used to use Comet or Ajax cleanser on mine with a scrub brush. It always worked for me.
  3. 383 240z
    383 240z
    Westley's bleach white and a scrub brush. Keith
  4. Fenders
    Fenders
    x2 !!
  5. lostmind
    lostmind
    Clorox bleach in a spray bottle , a scrub brush and goggles.
  6. Lone Star Mopar
    Lone Star Mopar
    Bleach White will dry your whitewalls over time, wich leads to em looking like ****. The best thing Ive ever found for cleaning whitewalls is one of those Mr Clean Magic Eraser's you buy at the grocery store with some mild soap and warm water. Works like a champ every time.
  7. Xtrom
    Xtrom
    from Forman, ND
    X2 on the Magic Eraser!
  8. mgtstumpy
    mgtstumpy
    Ajax with scourer and a lot of elbow grease.
  9. robber
    robber
    I've done well with all of the following... Ajax, Comet and Westley's.
  10. wallyringo
    wallyringo
    thanks guys i`ll get to it after work.
  11. Fopelaez
    Fopelaez
    Here we use a red brick with plain soap (pumice stone could be used) just scrub the white wall with soap, you will see the brick/stone acting like a sand paper, then just clean it with a brush and the same soap. It works great, better than all other stuff, try it in a small are and you will be surprised.
  12. Lone Star Mopar
    Lone Star Mopar
    Dude I aint getting a brick any where near them high dollar whitewalls, stick with a magic eraser you dont need all the harsh chemicals and voodoo...
  13. 55nailhead
    55nailhead
    SoS pads work good, rinse with water.
  14. Mooseandsqurl53
    Mooseandsqurl53
    from N.J.
    I used SOS on mine.
    had to do it maybe 6 times, but, it eventually came clean.
  15. surfcaliforniasurf
    surfcaliforniasurf
    i use chicken poop...works great
  16. ytt49
    ytt49
    from socal
    ^^^that sounds like a sh!tty idea
    sos pads work great
  17. 56don
    56don
    There is one in every thread.....:p
  18. 32fordroadster
    32fordroadster
    from Wisconsin
    Here are the recommendations from Diamondback Radials. A fine or medium sanding sponge works well. Any good cleaner works OK - Castrol Super Clean, 409, Simple Green, Greased Lightning - just to name a few. Avoid cleaners that contain bleach. Prolonged use of these cleaners can “dry” the whitewall surface. Do not use products such as Armor All on whitewall. This could cause slight discoloration. Whitewall surfaces tend to “dry” with time, heat, ozone, etc. A vigorous cleaning periodically will get rid of the dry surface and help maintain the tire’s beauty. Don’t be afraid to scrub.
  19. PJ_GARST
    PJ_GARST
    from kansas
    I use westley bleach white and a green scotch bright pad works great.
