whats the perfect rake for 32
Discussion in 'The Hokey Ass Message Board' started by elroy, Aug 31, 2012.
  1. elroy
    elroy
    Hey guys Im just getting to my frame. What is the perfect"hot rod" rake? If possible show a pic of the car with a idea of the angle of the running board,rockerpanel,or bodyline in degrees off horizontal. Thanks in advance.
  2. 4* in the frame.
    26" front tire 30" rear tire
  3. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Two of my favorites. Both totally different....both totally awesome!
  4. wetatt4u
    wetatt4u
  5. noboD
    noboD
  6. Streight8
    Streight8
    Depends how slippery the seats are.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Make mine nose down and **** up! HRP
  8. 56don
    56don
    I have said it before...HRP your truck has the perfect rake..
  9. A good starting point is top of the rails forward of the firewall parallel to the ground.
  10. hotrod40coupe
    hotrod40coupe
    I think this one sets perfect.
  11. iammarvin
    iammarvin
    from Tulare, Ca
    So sick of this question/disscusion. Everyone as different tastes, every style as different looks. Build what you like or thinks looks cool.
  12. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    I like to build them so when the spindles are at the same height the frame is level, then let the tires give the car it's rake.
  13. Not sick enough to join in though.
    Now I'm just guessing by the questions asked that the op know the look but not the details of how to get there. Pretty specific questions and request.
    Perhaps he's compiling a photo reference of rakes in numerical number.
    1* 2* 3* and on and on. Who knows exactly
    Yea there's lots to look at and lots of opinions and those can further segmented by period. But saying this one sits at 3* or that one is 5* is not an opinion, how it got there isn't an opinion either.
    Just once, once - I wish someone would say how big their windows are instead of what was chopped. " chopped 4" for example, is what you have to for reference to picture what went into the s**** bin yet looking at the proportions of what's left. Absolutely perfect if you can measure a stock one but if you can't , well you can't.
    Let's say yours was chopped too far and you want to make it taller. Well if all you had to go off of what came out of this or that one won't help you. But if you knew the windshield was 9" you'd be set.
  14. nwbhotrod
    nwbhotrod
    from wash state
    As low as you can get it. If you dont rub a littel your not low enouth
  15. tfeverfred
    tfeverfred
    Exactly. Wasn't that the original purpose of "big & littles"?
  16. elroy
    elroy
    HRP your truck is great, but what angle is it. And Bib i will be setting the frame as you said to get a look at it and see what the angle is.
    As for you other guys Im a machinist and cant just do anything by "eye"
    Thanks for all the input so far
  17. TANNERGANG
    TANNERGANG
    from alabama
    I like them low and good bit of rake....26" tires on tront...31.5" tires in back....just my opinion..........
  18. TANNERGANG
    TANNERGANG
    from alabama
    here's mine
  19. snapper
    snapper
    from PNW
    This .
  20. HOTRODPRIMER
    HOTRODPRIMER
    I used a original frame but replaced the front cross member with a model A,,that gives the car a one inch drop,,I used a reversed eye spring and that drops it another inch add to that a 4" dropped axle and it totals up to 6" lower in the front.
    I used a reverse eye transverse spring on the rear without modifying the cross member.
    The tires add to the rake,,the front tires are Coker Cl***ics,560-15 (25.88) diameter & L78-15 (29.30) diameter on the rear,,,,5x15 & 6x15. HRP
  21. F&J
    F&J
    Well, not really 6" total drop from stock, because a 4" dropped axle is rated 4" from a straight line, and a Ford axle already has a stock drop. I think a 4" axle is only an additional 2.5" dropped from a stock Ford axle.
  22. Great ! Now back to the question that requires one numeral followed by the word "degrees" to answer.
  23. Baron
    Baron
    About a 3 inch rake looks good full fendered.
  24. tfeverfred
    tfeverfred
    In degrees, it seems like as little as 4 to 5 degrees would be good. Of course, wheelbase has to be considered. My T's wheelbase is 108" and the rake is about 5 degrees.
    Maybe someone can post some side views of 32's and you could measure a rough estimate.
    The pic above is about 5 degrees.
  25. TANNERGANG
    TANNERGANG
    from alabama
    Around my neck of the woods, we always said a car had a 2", 3", 6" etc. Rake to it.......never heard of actually doing it in degrees.......learn something every day.
  26. Tony
    Tony
    I built this with 2 degree's in the ch***is, the rest is rubber rake.
    Everyone has their own feelings..this is just mine. :)
    Tony
  27. Skirv
    Skirv
    Here ya go. Strraight side view of mine.
    hfh, ekimneirbo and JimSibley like this.
  28. A little lower in the back.
  29. tfeverfred
    tfeverfred
    I don't see how the "rake" or "stance" is done in inches. People are saying a 4" rake. What's the 4" in reference to? Are they saying that the rearend is 4" higher than the front?
    Take a side view pic of a car. Draw a horizontal line along where the tires meet the street. Now, draw a line along the length of where the main body line ( or frame depending on the car ) would be. Now, draw the lines, so that they meet in front of the vehicle. The degree of that angle would be the "rake".
    I hope I explained it right. It would be easier if I could draw it.
  30. tfeverfred
    tfeverfred
    On this car, accounting for the picture and using the main body line as a point of reference, it seems to be minimal. Like.... 2-3 degrees. But that's going by a pic on a monitor and the slight angle in the side view. That pics not a dead-on side view. But I think you see what I'm getting at.
