"Felt Tip Marker" stain on Marine Vinyl- Help!
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Sep 2, 2012.
  1. fordstandard
    fordstandard
    How do i remove ; Magic Marker (Felt Tip Marker) that left a black line on my marine vinyl ?
    I tried - Dish Wash Liquid Soap/ Magic Erase Sponge ... no luck
  2. HOTRODPRIMER
    HOTRODPRIMER
    There is a produce called goof off,,it will do the job. HRP
  3. daddio211
    daddio211
    Hairspray! Yes, really! The aerosol kind works best.
  4. theHIGHLANDER
    theHIGHLANDER
    Try it in an incon****uous area 1st, but rubbing alcohol will remove permanent inks. If it's colored it may "bleach" the color, that's why you want to test 1st. If not rubbing alky, denatured alky also works. Blot it up while it's wet and avoid scrubbing it in if it's a light color. Flush with water after and dress with a quality vinyl protectant.
  5. Boyd Wylie
    Boyd Wylie
    mineral spirits
    non-acetone nail polish remover
    whitening toothpaste
    liquid hand cleaner [no pumis]
    these may have to be applied multiple times
  6. Steve Ray
    Steve Ray
    Nail posh remover with acetone will also get out permanent inks, but it also melts some plastics, so try it on an incon****uous area first.
  7. 1964countrysedan
    1964countrysedan
    from Texas
    I think your screwed.
    You might test some Rosonol lighter fluid in an incon****uous area, checking for discoloration.
    What color is the vinyl?
    Find or mix some paint.
  8. Gator
    Gator
    from Statham Ga
    WD-40 works too.
    I've also had good luck w/ Goof-Off.
    Those 'Magic Erasers' your wife has hidden under the sink are good too...
  9. 400 4spd.
    400 4spd.
    Lacquer thinner will cut it, too.
  10. 390kid
    390kid
    x2 for wd-40
  11. mj40's
    mj40's
    X2 Used it years ago to take price ink off canned items in the grocery business. Test an area first before using it on the good item.
  12. pinkynoegg
    pinkynoegg
    windex. it will take it right off
  13. vg62truck
    vg62truck
    Not kidding here, "OFF Bug spray"
  14. Moonequipt13
    Moonequipt13
    I suggest mixing everything suggested here together
  15. HotRod31
    HotRod31
    I did the same thing silver sharper on black vinyl, wife used WD-40 worked pretty good. Tried acetone on a s**** piece and it faded it.
    Later, Mark
  16. Buddy Palumbo
    Buddy Palumbo
    I agree ... WD-40
  17. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I can almost hear the icebergs melting :rolleyes:
  18. seb fontana
    seb fontana
    from ct
    boom !!!
  19. oldsmerc
    oldsmerc
    from seattle
    Vinyl is pourous so if it is a permanent marker you will never get it all out. Marine vinyl is not all the same. General Tire (Mississippi plant) used to make marine vinyl with a top coat called PreFi**. If you are lucky and have that product it will respond to the above suggestions without damage. Be CAREFUL and good luck.
  20. kombi66
    kombi66
    from stockto ca
    i have used a dry erase marker to get sharpie off of a white board some idiot wrote on, not sure how it would work on vinyl
  21. pinkynoegg
    pinkynoegg
    it wouldnt
  22. F&J
    F&J
    I have been sewing some white marine vinyl lately, and a hamber said to mark the sew lines with a lead pencil, and that you should use an eraser to clean off those lines later.
    It worked for me, and an eraser took off some contact cement also. The marine stuff does seem to have an outer layer to prevent stains like you'd expect to get, on boats.
  23. john~N~dallas
    john~N~dallas
    pretty sure it will work on vinyl... but when i was younger we used to carry rubbing alcohol wides into the bar and when they marked a big black X on our hand.. walk into the bathroom stall and wipe it right off...works on skin should work great on vinyl. not that i condone this type of behavior anymore.....
  24. Acme Speed Shop
    Acme Speed Shop
    MODERATOR
    from so cal
    Yep. Just dampen a rag and wipe or dab the sharpie off.
  25. river1
    river1
    Foam shaving will work also
    Later jim
  26. Parts48
    Parts48
    from Tucson, Az
    ..I am quite surprised no one mention a Mig welder..
    I'd use the Goof Off..
  27. 1964countrysedan
    1964countrysedan
    from Texas
    This has turned into some serious ****!
    I hope fordstandard comes back with a "removing felt tipper marker stain from marine vinyl" tech week thread complete with before, during and after shots!
  28. magoo
    magoo
    I have used brake fluid to take ball point ink off vinyl. Allways try it in a hidden area first.
  29. go-twichy
    go-twichy
    monkey placenta?
  30. n.z.rodder
    n.z.rodder
    I don't want to know how on gods earth some of you found these solutions out.
    I'd try get a large sample of vinyl, a felt tip and then try any or all of the above, with the exception of go-twichy's example! Before you try them on the seat.
    Scotty
