cheap tool tech.
Discussion in 'The Hokey Ass Message Board' started by Count Scrapula, Sep 2, 2012.
  1. Count Scrapula
    Count Scrapula
    from Mid TN
    Nothing fancy, just some tools I fabbed up to do the job. First is a brake line strap fabricating tool. Just some stuff I had laying around the shop...some angle, a piece of square stock, a piece of round stock, and a hinge. I tacked the square and round stock to the angle as shown and then tacked the angle to a hinge to keep everything aligned the same every time you close it. You have to leave some space to compensate for the thickness of the material you'll be using. You can use stainless or mild steel. I use 18 ga. Just lay the angle on your vise jaws and press out as many as you want. I use a hole punch for the hole.
    Next is a couple of thread chasing tools. Ever had one of those bolts that had the threads messed up on the end or even in the middle. I made this tool to clean up threads in those situations. I took a cheap pair of pliers and tig welded a grade 8 nut to them and then cut the nut into with a hack saw. Now you can clamp the pliers on the bolt anywhere hold the pliers with one hand and use a ratchet to back the bolt out cleaning up the threads.
    The last one is a thread chaser I made by grinding a groove in the side of a grade 8 bolt and welding on a T handle. I use it to clean all the threads in engine blocks when I'm rebuilding one. I know I could use a tap to do the same thing, but taps are tapered and most of the time pointed and won't reach all the way to the end of blind holes in engine blocks. Besides this saves wear and tear on your taps.
  2. Bentrodder
    Bentrodder
    from Cotati
    I am gonna steal these. Nice job.
  3. good job mate. i'll be using these for sure
  4. flamedabone
    flamedabone
    Your brake line clamp tool is genius....
    Nice work, -Abone.
  5. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    x2.
  6. RayMiller
    RayMiller
    Hey submit your ideas to matco tools and they will pay you cash, I say it on their site this morning when I was making my tool box payment. I think they offer like 2500 for good ideas and these are pretty good.
  7. Count Scrapula
    Count Scrapula
    from Mid TN
    Thanks Ray, I'll definitely look into that. I don't know if any of them would have any commercial appeal though.
  8. 1964countrysedan
    1964countrysedan
    from Texas
    COOL TOOLS! Your clamp forming tool triggers unlimited possible variations.
  9. 55 dude
    55 dude
    getting ready to plumb brake lines and will try your idea out! show a picture of the hole punch your using.
  10. Count Scrapula
    Count Scrapula
    from Mid TN
    We have a big sheer at work. I sheer off a piece of 18 ga about 1/2" wide and keep it around the shop. That gives a nice straight strip to work with and ensures that all your straps will be the se size. The hole punch I'm using is a cheapo from Northern Tool. I'll try to post a pic later.
  11. willowbilly3
    willowbilly3
    from Sturgis
    Good tips, thanks. I have been using the bolt thread chaser idea for years, lots of times it's for an odd sized or large hole that I don't have a chaser for.
  12. that thread chaser is genius
  13. charleyw
    charleyw
    Great ideas, Thanks
  14. BORRACHO13
    BORRACHO13
    from Menifee CA
    wow great tool man thanks
  15. lawman
    lawman
    Very Very nice work !!!!!
  16. Tech week entry I hope.
    I bet a Crafty fella like you has more too.
  17. damagedduck
    damagedduck
    from Greeley Co
    you can bet your **** i'm stealing these!!!!!!
  18. Count Scrapula
    Count Scrapula
    from Mid TN
    Here's the hole punch I use, and a pic of how the well the straps fit on the brake line.
  19. PackardWood
    PackardWood
    from JoCo, NC
    Consider it stolen sir!:D
  20. Hackerbilt
    Hackerbilt
    Great ideas that I'll eventually make use of I'm sure! :D
    Thanks!!!
  21. Buddy Palumbo
    Buddy Palumbo
    I like the ideas - good job
  22. Firepower71
    Firepower71
    from Atlanta
    So simple and so useful. great stuff. Thanks for sharing.
  23. hoggyrubber
    hoggyrubber
    thanks for sharing.
  24. Sphynx
    Sphynx
    from Central Fl
    Better hurry I am trying to get a patent already. But really those are some great ideas thanks for them.
  25. 1950heavymetal
    1950heavymetal
    great tool ideas! thanks for the ideas.
  26. JackdaRabbit
    JackdaRabbit
    from WNC
    All great ideas which I'll be copying for sure. Cept I think my T handle will have friendlier smooth stock instead of threaded.
  27. cigarcaptain
    cigarcaptain
    Yes I like this a lot. I wonder if the flanger/hole punch thingy would make a hole in that 18 gauge? These tools are cool.
  28. HellsHotRods
    HellsHotRods
    I want to see the brake line clamp produce stainless clamps, seems you would have to really apply a lot of pressure for SS
    I like the last tool, great idea!
  29. mwhistle
    mwhistle
    from sacramento
    Very clever. Thanks.
  30. Ruiner
    Ruiner
    I just made one of the brake line clamp dies yesterday after seeing this and it works perfectly, and I even have the same hole punch...thanks for the helpful tech!...
