Projects *oldsboy*_T-sedan build
Discussion in 'Traditional Hot Rods' started by oldsboy, Jan 11, 2011.
  1. Hitchhiker
    Hitchhiker
    And you call yourself a hot rodder....Shame on you.....
    40Mike likes this.
  2. Kume
    Kume
    Jesus wept! how did I miss this build - perficK!
  3.
  4. lowtruck
    lowtruck
    from Omaha
    This seems like a good time to talk about the chop again. I just did my film from that weekend, here are a few shots...
    I dig the steering setup. I can't wait to see the hoop when you get it done.
    Shadow Creek and brEad like this.
  5. scrap metal 48
    scrap metal 48
    Chop Looks great....
  6. Car
    Car
    from the desert
    love the chop!
  7. KustomCars
    KustomCars
    from Minnesota
  8. Jeem
    Jeem
    Alliance Vendor
    Heavy chop but I like it! Looks really cool.
  9. langy
    langy
    Just caught up with this build, pretty good work so far, well done
  10. I like the looks of the front-end with the '32 grille. Car sits real low, especially with the axle you're using. Looks like a straight axle.
  11. Pinstriper40
    Pinstriper40
    Looking good! Keep it up!
  12. oldsboy
    oldsboy
    Thanks everyone for checking out the thread and special thanks to lowtruck for posting some unseen photos. Its hard to imagine how tall it was now looking back!
  13. NealinCA
    NealinCA
    Looking great! I love the hard chop and the steering set up is a neat solution.
    Keep the progress pics coming.
    Neal
  14. nice chop! I really like angle chops!
  15. Tim
    Tim
    from KCMO
    a quick bump feinding for updates of little welded bits haha
  16. hotrod--willys
    hotrod--willys
    Just think. it could have looked like this.;)
  17. TexasSpeed
    TexasSpeed
    from Texas
    I think that chop's spot on! Looks much meaner that way.. I love it.
  18. TexasSpeed
    TexasSpeed
    from Texas
    The emergency handle brackets look great. I'm definitely stealing that for my '39 trans, just FYI.
  19. oldsboy
    oldsboy
    Thanks TS!
    Unfortunately I can't take credit for the idea....that has to go to Mr. Vern Tardel.
    It's super slick though, just ended up using a cleaned up and recontoured piece of 1 x 2 angle iron and a few nuts and bolts.
    40Mike likes this.
  20. oldsboy
    oldsboy
    So I was able to take an extra day off work this weekend and get back to the car and pick up where I left off. After a few days the steering is in and as I look at the photos, I'm not sure how it all worked out the way it did. This was one of those deals where I think luck was on my side regarding how close the clearances all ended up being.
    In the end I'm pretty happy with the way it all came out. Currently the steering rack is still in mock up phase as I ran out of time to finish weld it. I'll do that and clean it all up over the next few weeks.
    The icing on the cake though was being able to have my grandfather help out on the whole thing, run the torch , and help me bend up my headlight mounts. They also need some polishing and some extensions but the torching is done.....
    Steering Box// Steering Rack:
    Headlight Process:
    I'll add photos of the finished mounts soon...
    I do need some help with the clutch pedal.
    I need to come up with a way to shorten it or do something to allow it to clear the bottom of the steering box. The brake pedal is perfect and clears nicely. The clutch is a little over an inch too tall. I figured I would get the box in at a comfortable working level then work out the pedals later. Any suggestions???
  21. N312RB
    N312RB
    from Burlington
    Either you have a **** ton of natural talent or you are holding out on us. This work is amazing, especially the body work. Nice job!
    brEad likes this.
  22. TexasSpeed
    TexasSpeed
    from Texas
    Very cool letting your grandpa help out. Something I would have loved to do myself as well.
  23. VonKool13
    VonKool13
    That car is so spot-on! Now it just needs some spider-web stickers, plastic rats, and a human skeleton for the back seat! :D
    brEad likes this.
  24. oldsboy
    oldsboy
    Thanks N312RB, I know its not up to the caliber of some a lot of builders on here, but I'm trying. Its coming out pretty well for not having a garage or shop to work in at least...
  25. Tim
    Tim
    from KCMO
    Lupus I think I'd cut the top off of the pedal leaving enough to heat and bend a tab that you would then drill a hole in to bolt the pad on.
    Seems like the easiest way to do it with out changing really anything but were your foot lands.
  26. KustomCars
    KustomCars
    from Minnesota
  27. Chryco36
    Chryco36
    Cut your hair
  28. oldsboy
    oldsboy
    Yeah yeah...those were the college days....rest ***ured it's since been cut.
