Hot Rods 1936 Ford Pickup windshield mod.
Discussion in 'The Hokey Ass Message Board' started by fasttrack, Sep 2, 2012.
  1. fasttrack
    fasttrack
    from Pa.
    I am thinking about trying to make my windshield solid . I would like to keep it closed and sealed so I can remove the crank stuff inside the cab.
    Is there any oversize seals for the windshield and trim so it would look factory? If not i guess i will have to use the stock frame and make a mount so it looks stock.
    Thanks for your guys help!!!
  2. Nemosgarage
    Nemosgarage
    Need to keep the windshield and vent nothing like reall good air flow on a nice day wouldn't trade it for a/c
  3. blue 49
    blue 49
    from Iowa
    My windshield hardware and frame were beyond repair so I made a pinchweld for a rubber mounted gl***. It doesn't look original but I think looks OK.
    Blue
      151.5 KB
  4. fasttrack
    fasttrack
    from Pa.
    That is what I was thinking of doing. It look fine! Where did you get the rubber seal for the gl***? Also is the gl*** custom or can it be ordered?
  5. blue 49
    blue 49
    from Iowa
    the rubber is a universal gl*** channel from JC Whitney. The gl*** has to be custom cut from a pattern you make.
