** Tech Week** Casting a metal nameplate for your car
Discussion in 'The Hokey Ass Message Board' started by Smokey, Sep 3, 2012.
  1. Smokey
    Smokey
    This is a guide for a simple way to cast a nameplate for your car. This method and materials, however, lends itself very well to making other things such as dash trim , knobs, etc. I do a lot of aluminum casting for myself and it is great to have the means to do it but, the one thing that probably keeps most people away from aluminum casting is the extra work or expense of the foundry setup and its learning curve. There is an answer to this, and it is very simple. I have been using it for years to make all sorts of parts (trim, knobs, horn ****ons). Pewter works great for this process. It has a low melting temp around 450-475 F, machines well, polishes up well, and because its main ingredient is tin, it looks a lot more like chrome than polished aluminum. “Real pewter does not contain lead” It is nearly all tin with some antimony and a couple percent of copper. I always keep an eye out for it at antique shops, flea markets, and garage sales and try to pick it up cheap to add to my stash. You can buy it new in ingot form but you are going to spend about $16 a pound. Below is an example of some pieces that I have collected for use. You might be thinking that pewter is just too soft to be of any good. Just take a look at the following photo and realize what it has been used for through the centuries. Cups, mugs, plates, silverware, pitchers, flasks, jewelry, ****ons, and on and on. It will work just fine.
    Now with that out of the way. The nice thing about pewter’s low melting point is that you have a lot of options for what can be used as a mold. In this case we will be using medium density fiberboard – MDF is cheap, readily available, and easy to work with. Get yourself a chunk and print off your lettering from your computer using the inkjet printer. On this project I used a 250 pt font. Tape it onto your mdf board and use some Xylol on a rag on the paper and it will transfer the lettering to the board. In reverse of course, which is what you want.
    Next take your router with a suitable size cutter for your letter size and route out the lettering. I went about .300 deep and this depth is helpful for the mounting studs.
    Here it the highly technical part. Because of the melting point all you need is a tin can for your crucible, propane torch, and your cut up s****s of pewter. It doesn’t take too long to melt and then just pour into your mold. It cools off rather quickly so you get very little smoking.
    It is better for you to have your mold be too full rather than not full enough. I usually just mill off the back side to make it flat. You can use your router and a couple boards on each side to do this also. Pewter is soft enough that it's not difficult to shave it off.
    This is the neat thing about using mdf as your mold material. (This is not totally necessary but it speeds up the de-molding process.) Take and trim around to leave as little material as possible. Then just drop the whole thing in a bucket of water and in 30 to 60 minutes the mdf will fall right off.
    You can now put the mounting studs in. I use 10 -24 bolts and I just drill the hole in the back the same size drill bit as if you were going to tap it but instead just screw them in. No tapping. Then just cut them to the right length for your situation.
    Now all that is left is to polish your nameplate and mount. I like to spray some flat black paint on the sides and I think it just looks a little better. Hope that you all have found this useful. With a little thought and imagination this can really be utilized on other areas of your car, inside and out.
    Smokey
  2. N312RB
    N312RB
    from Burlington
    Woah! That is pretty cool, I never thought of doing anything like that, I guess one is just limited by router bits and imagination now.
  3. Teal32
    Teal32
    I'm gonna give it a try. Thanks for the tips.
  4. Crusty Nut
    Crusty Nut
  5. 117harv
    117harv
    I have a couple of questions, how do you spot pewter, I wouldn't know what it looks like. Also it appears that the router bit has a flat end and not round, does the edge of the piece you made keep the crisp edge, it's hard to tell in the pic? The mold looks very nice, you did that freehand just folowing the ink transfer? Great tech, thanks for posting.
  6. 41 C28
    41 C28
    Thanks for the inspiration. I can see some things I'd like to make.
  7. Very cool.
    And seems so easy.
    I too would like to identify pewter.
  8. lango
    lango
    from Georgia
    That's neat! Thanks for putting that up.
  9. Smokey
    Smokey
    Thanks for the responses.
    117 harv,
    Let’s see if I can explain how to tell if is pewter. To start off with it will usually have a touch mark on the outside bottom in the middle of the piece. Usually it identifies it as pewter. However there is some out there that might say American pewter and that is usually some alloy of aluminum and is not useful in this case. If it is an aluminum alloy or silver plated br***/copper, it will have a ring to it when thumped with your finger, pewter has a dull sound. Also if you took one of those goblets that is show in the first photo the thin cross section could be bent or deformed with your fingers. Pewter is about the only metal, that the examples in the photo, would be made of, that would melt at such a low temp. After a while it will be easy to tell. I usually always go by the sound.
    Yes the bit is flat and that is so I can keep the edges sharp. Also since this is a one use mold there is no need for draft. I know the pics turned out kind of ****py so sorry for that.
    Freehand. When routing I find the best way is to hog out most of the waste material leaving just enough of the outside line to clean up at full depth in one final p***. About the width of a pencil line. Make sense? It also helps to use that little laminate trimmer as a router, great control.
    41 C28 and all,
    If you have access to a metal lathe it turns like ****er and polishes like a mirror. All you have to do is make a mold to pour a chunk close to size to what you are making. For example I needed an transition ring to go from a smaller old horn ****on to a steering wheel. I just cast a ring using mdf as a mold. When polished the finish looked just like the chrome horn ****on. It wouldn’t have if it was aluminum.
    Smokey
    brEad likes this.
  10. Molonewolf
    Molonewolf
    Thats cool always looking for something new to try.
  11. scrap metal 48
    scrap metal 48
  12. n847
    n847
  13. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    My kid wants to get into sand casting and this would be a great start, thx.
  14. EnragedHawk
    EnragedHawk
    from Waco, TX
    Oh yeah, gotta try this... Thanks for posting!
  15. BAJ
    BAJ
    from Ontario
    Thanks for the article. This is something I need to try.
  16. FORDY 6
    FORDY 6
    Great tech post! Just back from Colorado...planning on calling, to say thanks for milling my axle...THANKS!
    Steve
  17. bct
    bct
    I look forward to trying this one day....... thanks
  18. fastcar1953
    fastcar1953
    very good tech thanks
  19. The price of old pewter stuff just went up 500%.
  20. 55 dude
    55 dude
    great tech and also great write up!
  21. Buddy Palumbo
    Buddy Palumbo
    Very cool tech - now I just need to find an excuse to use the idea !
  22. tinmann
    tinmann
    A high school metal shop teacher thanks you..........
  23. cigarcaptain
    cigarcaptain
    This is a good one , thanks
  24. slick377
    slick377
    Now that's clever! really gets the brain spinning with possibilities...
  25. woodbox
    woodbox
    Likin this one! I see a project for the kids coming up!
  26. looks like i'll be hitting the secondhand shops this weekend. cool tech thanks for posting.
  27. koolkemp
    koolkemp
  28. mow too much
    mow too much
    Now that's pretty neat.
  29. Cool! I even bought myself a small crucible with a long handle off Ebay... I ***ume that since it melts at such a low temp, that once it's cast, you can heat up slightly and bend it fairly easy... So the MDF could be used to make... trim... bullnose hood ornaments, grill teeth, Low production club plaques, etc.
  30. Smokey
    Smokey
    4t64rd-
    Really no need to heat it up again because you can bend it cold fairly easily, in relation to thickness of course.
    Yes you are correct, and that is the point I was trying to get across you can make all those type of pieces and use a wide variety of mold materials, not just mdf. Other materials work really well such as plaster (very dry), bondo, and for really detailed parts you can use rtv silicon because of pewter's low melt temp. I didn't mention the silicon before because I was trying to show the low cost/low tech aspect of this. Your limiting factor will probably be the cost of the pewter itself.
    Smokey
