Early Ford steering box internal question
Discussion in 'The Hokey Ass Message Board' started by 31' A Bone, Sep 3, 2012.
  1. 31' A Bone
    31' A Bone
    from So Cal
    I know the 37-48 p***enger worm and sector can inter-change with the F-1 box, but what about the 37-47 pick up worm and sector? Are the 37-48 p***. worm and sector the same as the 1/2 ton p/u's?
  2. thunderbirdesq
    thunderbirdesq
  3. 31' A Bone
    31' A Bone
    from So Cal
    same ratio then too, right?
  4. 31' A Bone
    31' A Bone
    from So Cal
    can anyone 2nd that?
  5. 31' A Bone
    31' A Bone
    from So Cal
  6. onekoolkat1950
    onekoolkat1950
    parts are interchangable.
  7. NealinCA
    NealinCA
    I second...
  8. Bruce Lancaster
    Bruce Lancaster
    Same. Get yourself a '28-48 book! You solve this sort of thing by looking up a part that would have to be identical, like the sector or a gasket. The worm was sold only on the shaft, so there are a dozen variants, but the book details out total length and location of lock collar hole so you can figgeritallout.
  9. thunderbirdesq
    thunderbirdesq
    Yep, I've had several "different" 37-48 worm gears, different machining marks, part numbers, etc... but they all are dimensionally identical.
