so i just got a 1932 5 p***enger chevy coupe, it has the p***enger door and 3 spare doors, none of which are the drivers door, one of the spares is a drivers side door but it is much narrower, maybe from a 3 window or something, i was wondering if anyone has widen one of these before, since i have 2 extra doors for donor material i figured it would be the easiest and cheapest way to get a drivers door...thoughts?
Probably a 4-door sedan door. A 3-window door if anything should be longer. Probably you can cut the end off the skinny door and cut another one longer and just have one seam, too.
If all else fails the Chevy parts manual states that the 32 Chevy model 32551 Coach which is a 2 door sedan uses the same door as model 32572 the 5 p***enger coupe. They should be fairly easy to find.These guys say they have a used one. You can also try VCCA chat and do a search of place a want ad. http://www.ctcautoranch.com/Used Parts/Used Parts Sub Pages/Sheet-Metal.html
I go to several sources and all have been very good at providingme with needed information. The Filling Station in Lebaon, OR, Larrowes in Big Sandy, OR and Bow Tie Bits. Another vendor who is loaded with knowledge about these cars in Patrick's in Arizona. Normbc9
